mga sir i dont know if dito ko ba dapat i post to... ask ko lang sana mga sir kung anung klaseng subwoofer to? pang kotse din daw eh...may amplifier na daw to... salamat sa mga magbibigay ng info...![]()
it's a self-contained car sub-woofer with amp. Just wired it up to your existing speakers or head-unit add power and it should be ready to go boom-boom. It's a convenience thing with some owners who would need to remove the sub-woofer in case he needs to bring something large in the trunk.
You can locate it in the trunk or rear seats.
may v12 nito pero im not preferring this kung bass lover ka mahina .. ako 4k inabot nung sub ko tsaka ampli pang loud and clear
Well, it is "weaker" compared to a full custom pair of 12" subwoofers mounted in isobaric boxes going at full volume. I have gone through that "boom-boom" phase in my own car many years ago (and probably resulted in some higher frequency hearing loss in the process).
The one in the picture you posted might have a pair of eight or ten inch subswoofers mounted inside the box. It wont be earth shattering but should provide enough additional "thump-thump" you would want before investing into a more expensive custom subwoofer setup.
It is good enough for most popular music. Of course if you like BASS music, you will really need to invest more.
This is called amplified sub.
This is good for a vehicle without a trunk but if you're going to place it inside a trunk, I'm sure mabibitin ka.
dba chinese generice subs to? a member of clubisuzucebu sabi nya sana 4k+ daw V12 subwoofer nya, it looks the same i think
mga V12 karamihan ginagamit sa mga jeepney na amplifier. ewan ko lang sa sa seps ba nila, pero it sounds like lata except for the subwoofer of course
pareho dn ba ito ng concept sa blaupunkt na subwoofer? yung 11k ba yun? yung space saver. may amplifier na din yun.![]()
if you want the bass sound to be heard for a much farther distance yes bitin nga itong type ng subs because of its limitations... if you're really aiming for a much louder bass sound that will make people notice you or your car then i suggest you go for a custom made sound set-up to include all the seps and tweeters...
