Tulong naman mga kabaro o, kasi I'm having problems with my sound system. Simple lang naman e, kasi may static sound akong naririnig sa speakers ko pag naka-on radyo ko at umaandar sasakyan, naririnig ko yung arangkada ng auto. Pero pag di naka-on ang equalizer ko, ayos naman, pag lang naka-on ang equalizer doon maingay, ano kaya pwedeng fix doon? Salamat.
1. check the wirings of your equalizer. Make sure that they are not entwined with your power cables and antenna cable.
2. try to relocate the ground wire to another part of your cars metal body or in short try using other grounding points. Also try to scratch the paint of the metal point your using as this also might incur static.
3. if symptoms persist bring your car to a nearest car audio installer. :D
1. ano brand ng eq mo? baka proline yan. try installing a relay sa power ng eq mo. madals kasi kapos na sa power ang linya ng accesories(this is where they usually tap power). gawin mo na lang trigger ng relay yung accesories then linya ka ng bago from the battery. put a fuse as close as u can sa may battery( in case may short)
