Results 1 to 10 of 16
July 13th, 2009 05:58 PM #1
Hi guys,
na-experience nyo na ba na pagnagrerevolution ka ng car or pagtumataas ang RPM mo habang bumabyahe ay parang may tumutunog sa radyo mo na parang static. parang nakikinig ka sa AM station. yun bang weeeeeeeeeeooowwww... hehe.. sorry, di ko ma-describe ng maayos pero yung naka experience nito malamang alam ang sinasabi ko. may electrical failure ba kaya? sa radyo or sa alternator? elsewhere? tulong naman dyan...
July 13th, 2009 06:16 PM #2
you can have a isolator installed to remove the electrical interference sounds.
Did you change something recently in your car? Like high tension wires or something?
July 14th, 2009 08:46 PM #3
na eexperience ko din to, sa akin naman kapag tumataas yung rpm saka lumalabas yung sound.
July 15th, 2009 11:26 AM #4
July 15th, 2009 11:28 AM #5
July 15th, 2009 03:27 PM #6
July 15th, 2009 03:52 PM #7
sir,
nagpa setup po ba kayo ng sounds? if yes, baka po masyadong magkalapit ang power and RCA cables going to your amp. isang cause po yan nung sound na naririnig pag nare-rev ang makina...
July 15th, 2009 04:46 PM #8
GH is referring to ground loop isolator. I had this placed in my old setup.
http://www.radioshack.com/product/in...ductId=2062214
July 16th, 2009 02:18 PM #9
July 16th, 2009 02:35 PM #10
sir,
the cheapest alternative would be to go to the audio store where you had your sounds done and ask them to fix the wiring. most of the time, arranging the wires properly will solve the problem.
try it our first sir. wala namang cost eh. if this still doesn't work, that's when i suggest you start purchasing other items (like the isolator, or a better pair of shielded RCAs).
