Results 1 to 10 of 10
March 31st, 2006 05:54 PM #1
eto story..
1. had v12 f-805 driving my separates and 6x9 coax
2. had mtx rt404 driving my subs
3. static busina and static sound pag nag-re-rev
here's what i did...
1. used v12 to drive subs, then used mtx to drive separates and 6x9.
2. tanggal static pag-nag-re-rev pero nandun parin static pag busina
already tried the following:
1. checked ground ng busina (move around sa chasis, engine, etc.)
2. lagay ng ground sa DSP unit
3. installed Y connector sa rt404 amp (meaning wala ng fader), humina konti static sa busina pero lumakas static pag nag-re-rev
4. used condenser to ground yung busina
HELP!!!
- Apr 2007
- 18
April 7th, 2007 06:32 PM #2wow same problem as mine.. til now wala pa rin akong makitang solusyon... tsk tsk..
akin d lang kalakasan ang static pero maririnig mo pag press mo ng busina..parang me ticking sound.
btw, this only happens if my aircon and headlights are turned on...
mga experts patulong naman diyan!
April 10th, 2007 11:30 AM #3
check muna relay, baka maluwag lang or busted.
nangyari yan sa oto ko. static pag bumubusina, tapos pagtagal tagal, nawawala na yung busina. kala ko horn button, tapos kinalaunan, kala ko yung mismong horn.
nung pina check ko, maluwag lang pala yung relay.
- Oct 2005
- 51
April 10th, 2007 11:44 PM #4Ganyan din problema ko dati. ang ginawa ko niliha ko hanggang lumabas yung metal don sa pinagkakabitan ng ground wire papunta sa amplifier. yon lang pala problema mahinang ground kaya nagkaka static
- Apr 2007
- 2
April 15th, 2007 06:22 PM #5yup, same on my case, but so far none when i push the busina.
i get the noise evertime i step on the accelerator(na-revolution)
perhaps someone could help.
pretty annoying to the ear kasi. tnx
February 7th, 2011 08:55 PM #6
Experiencing the same problem with my Fieldmaster right now. May static kapag bumubusina although kapag mahina lang yung radio reception. Once itinaas yung antenna, nawawala na. Hindi naman ganito sa iba naming sasakyan.
Stock audio setup
Jimson placed a choke filter dun sa (+) ng HU and condenser sa may horn wires. Meron pa rin
- May 2010
- 143
February 7th, 2011 10:56 PM #7
- Jun 2009
- 27
February 12th, 2011 02:16 AM #8palit ng ground wire to bigger one. kung malaki na ang ground wir pero my static parin make sure na di magkasama sa isang direction ang positive wire ng amp at rca cable ng stereo to amp. rca cable sa left side at power wire sa right drivers area.
February 13th, 2011 01:46 AM #9
have the same problem. but only happened when i installed amp for my separates. popping sound from tweeters when i use my horn. any help would be greatly appreciated.
March 11th, 2011 11:30 AM #10
these can be happen due to the following reason..
-driving your amp above to its own ability, sometimes too low impedance of the speaker and the high current passes to the audio system through the rca cables.
-the rca is touching or passing to a high current wire and so the signal from some accessory like horn goes to the audio system.
-bad power supply system usually the grounding system have a great resistance back to the battery.
-relay application, its an electromagnetic device that carries high current signal, and so that signal pushes very high current enough to enter the audio system, and,
-poor sound installation and wiring processes.
these is what you do..
start the engine and turn on your stereo and go to the amp, remove the rca, and get a new 1, run it from your head unit directly to the amp and try to click the horn button, if there still static, the problem lies from your amp to the speakers., remove the new rca and get a shorting plugs, (a shorting plugs is a set of rca soldered together at the other end) and put it to amp, these will mute your audio system, and try to hit the horn again, (if your having a crossover, try to that first), if it still there, remove the shoting plugs and put back the old rca, lower the gain in the amp probably 5volt input sensitivity, or to its lower as you know, and try hitting the button again. I think you hear nothing there even sound comes from your stereo, if these happen and the static is gone, that is the problem, your amp dont have much ability to drive your speaker, and so your overpowering it, or your power supply do not have enough current to do its ability, low power, bad grounding, etc.
But it is a chinese vehicle you can get spare parts from lazada or shopee right?
2024 Manila International Auto Show APRIL 4-7,...
