Results 1 to 8 of 8
Tsikot Member Rank 3
- Nov 2002
- 1,757
August 10th, 2010 03:09 PM #1I just can't get the behavior of my HU. funny thing is, minsan ok siya, minsan hindi kahit wala akong ginagawa. pero kung nagloko siya, sa left side lang siya nagkaka static. malakas na buzzing sound. this only happens when I play mp3s from either cd or usb. kung audio cd or tuner no problem.
TIA
August 10th, 2010 03:48 PM #2
You can probably check the grounding of the HU & the wirings. Maybe it could be also the issues with the encoding of the mp3s?
- Nov 2002
- 1,757
August 10th, 2010 04:19 PM #3i haven't really traced the groundings yet pero sinundan ko lang naman yung connections/wirings nung kinabit ko. baka natanggal yung ground wire sa body? pero bakit pag m3 lang?
regarding encoding of the mp3s, nirecode ko na sa highest possible standard (yung pasok pa rin sa specs ng HU) pero ganun pa rin.
thanks!
- Nov 2002
- 1,757
August 11th, 2010 09:01 AM #5
- Jun 2009
- 325
August 11th, 2010 11:33 AM #6Baka pirated version yang MP3 CD mo. Try to play original CD's for better sound quality. Consult the store where you bought the head unit.
August 11th, 2010 12:47 PM #7
If the noise is present only during MP3 playback, it's a HU problem. Bring it back to the store and have it replaced with the same model and try again.
If it's a line noise caused by the vehicle's electrical system, then you should hear buzzing/static regardless of the music source.
- Nov 2002
- 1,757
August 12th, 2010 08:43 AM #8thanks for the inputs! haaaay. problem is, binili yung unit sa abroad. i'll try to check kung global ang warranty and if there's a kenwood service center that can honor it. thanks again
Hybrids and EV
