mga sirs,tanong lang po ang size and wattage ng speakers(front and rear)ng xuvi 06 model, anong brand ba ang maganda?at mura.dito po kasi ako sa labas ng pinas. more power po.![]()
try mo yung 3 way na dynes maganda 6.5 in mids,3in midrange n 1.2in tweets
sir toolightz, thanks. pero anong size and watts ang para sa front and rear speakers? salamat po.sana makakuha akong info before i come home next month,ofw po ako dito sa ny.
blues
OFW ka kamo at ang abbreviation na nilagay mo ay NY. I assumed na nasa New York City ka. Am I right? Anyway, ano ba ang size ng cut off sa speakers ng sasakyan mo? Kung sa likod pwede din ang 6X9 na two way or three way speakers. Sa harap naman 6.5 na two way or three way also. If you want more detail sounds bolt on a component system.
1. Infinity Kappa series model 692.7i 6X9 two way or 693.7i three way.
Sensitivity.........................95 dB.
Frequency response (Hz).....35-25,000 Hz
RMS power range(watts)......2-100
Peak power(watts)..............330
Tweeter type.....................hard dome
Surround material................rubber
Mounting depth..................3 1/8 inch
Warranty..........................3 yrs.
Price................................around $200.00 pair.
Kappa series component system 6 1/2" or 6 3/4" model 60.7cs.
Frequency response...................45-25,000 Hz
Power range watts RMS..............2-90
Sensitivity................................95 dB
Mounting depth.........................2 inch
Warranty.................................3 yrs.
Price.......................................$300.0 0
Details: Plus One + woven-glass-fiber woofers. Neodymium motors. hi-roll rubber surrounds. 1" edge-driven Metal Matrix Diaphragm(MMD) dome tweeter. 18 dB/ octave, 3,500 Hz high- and low-pass external crossovers. tweeter adjusment circuits (0, + 3 dB). 2 ohm impedance.
If you notice the RMS power on those speakers which is 2-90 and 2-100 meaning you could use your H.U w/ outboard amplifier to fire up those speakers. But, you cannot get all the power of the speakers that you need. The way to listen more mascular details of that speakers is to use and outboard amplifier. Good luck.
