Originally posted by luckytruck just to offer a different option, you might want to take a look at what you will be doing in the long term. kung sa tingin mo, you will be constantly upgrading your soundsystem (this is what happens to most people who get into car audio), i suggest you get a set of high end separates muna for your front stage and run the off your head unit.
high end separates in the P8000 to 10,000 would be perfect.
then you save up for a nice 4 channel amp, that would be around 8 to 10,000 also.
then you can get a cheap sub for aybe P2000 pesos (its harder to differentiate between cheap and expensive subs versus cheap and expensive separates)
with this setup, if you do intend to upgrade, you will only have to sell your sub, the other components can still be used in your succeeding systems.
suggestion lang ito, para ma-iba sa mga sinabi na
andy
agree ako sa iyo andy,
10K is still a lot of money,
get a good seps first then save up for an amp and a sub.
