Results 1 to 4 of 4
    Oct 2013
    Hi! Need your help guys. How will i know if compatible yung sound set up ko?
    Kicker ES 124 12" Subs (305MM)
    Kenwood Class D Mono Power Amp (2CH)
    Pioneer Seps 2-way
    Pioneer 3-way Coaxial Speakers with 300W
    Pioneer 6" 280W Max 2-Way Component Speaker
    V12 Amp
    Sound Quest Wiring Kit
    BTW, nasira po yung v12 amp ko so naghahanap pa po ako kung saan pwede magpagawa. Naka MONO lang po ako ngayon. Any advice or comments po will be appreciated. If ever po magpalit ako ng amp (replace the v12) ano po ang magandang ipalit. Thank you. ^_^
    Aug 2010
    Quote Originally Posted by kcdee View Post
    Pioneer Seps 2-way
    V12 Amp
    1. Best to replace it instead. A V12 isn't all that expensive. Baka masmahal pa labor and repair costs mo.
    2. The best amplifier is the amplifier that fits your budget.
    3. Explain "compatible".
    Oct 2013
    Quote Originally Posted by jhnkvn View Post
    Naisip ko na din sir yung v12 if ever pagawa ko baka sayang lang din. May idea po ba kayo sa kenwood na amp? Ok po ba sya. Naisip ko po since kenwood na yung MONO ko baka same na din yung channel amp ko. Thanks again sa advise sir. ^_^
    Dec 2007
    Kenwood amps are way much better than the bootleg V12 amps.
    Try to know first the extent of damage of your v12 amp. and take it from there to decide.
    Don't worry too much on compatibility, what matters is that you should how to use your amps.
Sound Set Up Advice
