i've been seeing a lot of these, may JVC, AVI, V12 etc. slim sila na may 5, 6, 8 or 10" na sub w/ built in amplifier na pwede ilagay sa ilalim ng driver or passenger seat. may bumili na po ba sa inyo nito? any comments?
Its a powered subwoofers.
Powered subs is the simplest method for adding bass. They are designed for ease of use, so they often take up very little room in your trunk or cargo area. Most of this subs have speaker level input, which easily connect to your factory stereo just tap into your rear speaker wires, run power and ground wires, and enjoy the added bass. Pero, not as much strong than component subwoofers. Im using this kind of subs, its an INFINITY Bass Link w/ 10 inch subs a 200-watt RMS amp. Its an excellent addition.
The JVC, Kenwood and Blaupunkt are smaller powered subs sometimes fits under the seat of your car.
See my enclosure Infinity powered subs.
wow, ang ganda naman nyan, ang liit talaga ng space na kinuha nya. yung iba po any inputs? thanks
Kenwood. KSC-SW1 uses a 6 1/2 sub, powered by 150 watts maximum amp output. Dimensions: 15 3/4"W x 3 11/16"H x 9 1/16"D w/ wired remote control included.
JVC. CS-BB2 uses 6" sub. Output is 32 watts RMS x 2. Preamp and speaker level inputs w/ wire remote control included. Dimension: 11 3/8"W x 2 1/2" H x 7 7/8".
thanks po, saw pala AVI with 8" nasa 190w ata yun and with remote control din, ok ba yung brand na yun? tas may blaupunkt din with same specs ata. la kasi ako makita nung tulad sayo eh![]()
[quote=recklus;953572]thanks po, saw pala AVI with 8" nasa 190w ata yun and with remote control din, ok ba yung brand na yun? tas may blaupunkt din with same specs ata. la kasi ako makita nung tulad sayo eh[/quote
8" will do. Again this addition is not a big bass like other (component sub), just enought to add a better punch that your coaxial speakers cannot generate.
