need help tsikot guys, ano ba magandang set-up para sa strada ko..wala kasing space para sa subs na maganda at bumabayo na ng konti..patulong naman para may idea ako..pati suggest na din ng shop na mahusay gumawa..t.i.a!!! mabuhay ang tsikot!!!
ako i got the built in subs with amplifier that fits under the driver seat, then use jbl separates in the front and jbl 5inch speakers at the back. put in 1 inch thick rubber insulation for better sound quality in the doors. im satisfied so far with the work i have done on my strada. good luck on your strada project.
go the boss 8inch sub with built in amp, fits under the seat and looks reaaly nice and sounds really good.
as for the speakers, ill check the size again but i know 6x9 wont fit so i used the5inchs i think.
try putting in 1 inch rubber insulation in the doors, itll make ahell of a difference, i also used jbl amplifiers to power the rear and front seps.
ung sakin pioneer subs with built in amp.. medyo di ako masyado satisfied sa bass nya pero pwede narin.. next project ko sana install ung 2 din dvd,tv multimedia receiver.. pero im not sure if mag fit cya.. anyone who tried to install a 2 din stero sa strada nila if it fits? or if my konting space panu ginawa nyo to fill it up
check thislinkforthe 2dinpanel for the strada...
http://cgi.ebay.ph/MONTERO-SPORT-RAD...item33603c6c3b
