Results 1 to 20 of 20
    Apr 2008
    ask ko lang kung pede yung home speakers sa kotse may gumawa naba nito?
    tia
    Jun 2006
    Not 100% sure but i think it can work. Your amp, if you have one will but at half the power output. So even if it works, its not ideal.
    Home speakers are typically 8 ohms while car speakers and amps are normally 4 ohms. So your amp will see an 8 ohm load and power output will be halved.
    Sep 2005
    I remember a friend of mine back then in High School: The year was 1995 and the ride is a 1981 Toyota Corolla DX. My friend wanted his sounds to go "boom-boom" so he took the speakers from their home stereo system (yung malalaking "old school" type) and placed it in his trunk, used an el-cheapo amplifier and alas! May "boom-boom" na sya! hahaha!
    But seriously, he took them off after about two months when he was able to save enough cash to buy a Targa Sub.
    Share ko lang...
    Feb 2005
    Basta pareho impedance i.e. ohms requirments ng HU mo at yung stereo mo sa bahay, pwede. Ginawa ko na yan - tagal na: owner type jeep at yung dati kong Lancer box-type.
    Oct 2005
    same as russpogi's, i have a friend with her toy car named 'freaky' an 81 Mirage. was sold to her for only 10k. she just traded a celfone for it. tas bara bara nalang ginamit. no rear brakes (it screeches when braking), home speakers literally (actually works), matress for rearseats... hehehe i miss that car.
    pwede yan.
    yung sounds ko sa garahe namin, my old alpine HU + 2 set of speakers from my old sony mini-component.
    nung college days ko, baliktad naman, sanyo radio cassette unit + 2 pioneer 6.5" speakers naman ang gamit ko sa ford escort ko.
    Apr 2008
    ok try ko tom at least may feedback,kakabit ko kc bose speaker n 8" ppalitan ko kc yung sa stock para medyo ok nmn ang sound ng lancer ko.tnx. update ko kayo kung ano mangyayare hehehe
    Oct 2008
    pude yan kasi dati yung friend ko may nissan sentra cra yung isang speaker kaya kinuha nya yung speaker sa radio nila tapos kinabit sa dalawang wire. gumagamit nalang siya ng adaptor na tape na may wire (d ko alam kung ano tawag dun bsta tape na may wire) papunta sa Mp3 player niya
    May boom boom na siya
    May 2007
    Quote Originally Posted by sherwinlou View Post
    tia
    There's no harm in using 8 ohm speakers in a car.
    Sep 2005
    I know someone who solved that problem with impedance mismatching.
    When he fitted 8[SIZE=4][SIZE=2]Ω speakers in his car, he also installed his mini-compo stereo under the dashboard. And f[/SIZE][/SIZE][SIZE=4][SIZE=2]or more boom-boom, he used his desktop pc's active sub. [/SIZE][/SIZE]
    [SIZE=4][SIZE=2]Buti na lang hindi sinama yung turntable.[/SIZE][/SIZE]
    Aug 2008
    hi mga sirs, makisuyo lang po...
    what can u say about this: i have a spare altec lansing sub kasi sa bahay (1st gen in wood box pa, it is the 2.1 type, kaso lang hndi na gumagana kasi yun 2 monitor cube speakers nya that's why). i'm planning to use this active sub sana to go with my stock set of speakers (99 civic).
    can this be possible?
    Yung kuya ko naalala ko pag may gimik sa greenhills nung uso pa pormahan ng auto dun sa weekend, nilalagay yung akai speakers ng bahay sa likod ng DX corolla hatchback niya
    Sep 2005
    Pwede naman ... as long as you're satisfied with the sound and look.
    Yun nga lang, you have to feed it at line-level from your head unit. Kung wala there are adaptors that convert speaker-level signals to line-level ... but it kinda defeats the objective re: costs.
    You also have to figure out a way to remotely switch the sub, or else you'll have to turn it on/off manually. As for the power source, if that's the same as the ACS45.1 you can just bypass the internal power supply (220vAC-to-12vDC) and hook it straight to 12vDC.
  14. #14
    4ohms lang dapat ang auto speakers. ang sa home ay kalimitan ay 8ohm ang operating..
    just check that parameter. pag di 4 ohm wag mo gamitin sa auto baka madamay pa HU mo..
    Aug 2008
    Quote Originally Posted by StraightSix View Post
    ah i see.... thanks for the detailed explanation sir. i need to check the ohms output din pla nito.
    thanks din TS
    Sep 2005
    Quote Originally Posted by hakkinen View Post
    There's no need for that.
    If you use an 8Ω home audio speaker and connect it to the head unit's 4Ω speaker line, there will be an impedance mismatch. Not that it's really a bad thing ... It will still work OK. What's to be avoided is using 4Ω car speakers on a home audio amplifier, if you don't know what you're doing.
    But what you have is an active subwoofer, which has a built-in amplifier. The speaker is already matched to its amplifier (by design). Your active sub is fed thru its line-level input, which has a high impedance. The Sub Out or Preamp Out from the head unit has also high impedance ... so there's no need to worry about speaker impedance mismatching.
    It's the impedance mismatch between the speaker and amplifier that's worrying people here.
    Aug 2008
    ah, so that clears things up for me. in theory, that was also the same thing that's floating in my mind, you just crystallized it for me. thanks for this sir.
    well bottom line is, i'm really trying to make full use of this idle sub speaker na matagal nang naka-tengga dito sa bahay... sayang nman. truth is, im not really into this chest pounding, ear splitting subs talaga, im past that already (i have some occasional kick tho ). all i need is a decent mid set-up that is flexible enough to handle most of the music genre that i'm into. i also consider the space that the sub will eventually eat up in my trunk space, hence this altec lansing sub being a bit smaller.
    then i saw my old sub sa tambakan, hehe....
    Sep 2005
    You're welcome. I'm sure that spare Altec Lansing sub will be worth the effort.
    pwedeng pwede yan kung tunog lang hanap mo, minsan sa mga jeepney kita mo mga inasemble lang na speakers from home speakers..
    Mar 2007
    mga sirs, im thinking of installing my 2.1ch bose companion speakers on my bug din sana. im not into boom-boom kasi mostly operas and love songs ang pinapakinggan ko lang (weird bah?). i used to pair it with my B&O MP3 Player and they sound really cold and sweeeet! im not gonna use any HU na, thus no amplifiers na rin sana. im just using the car to drive from work to office.. about 30minutes/day so why invest 30k to 50k for sound set up alone? i will if it's an RV. im just trying to be practical kasi.
    pero paano kaya ang mairerecommend nyo na arrangement of 2 sattelites and the subwoofer? all under the dash? subwoofer at the back, sattelite under the dash?
    otherwise, if i will set up a car audio system.. maybe mga 15k to 20k lang ang makakaya ko. and as much as possible, they should match the sound quality as decent as my bose companion's... and would that be possible in the first place?
    ano kaya magandang option mga sirs?
home speakers pede b sa kotse?
