Results 1 to 10 of 13
June 27th, 2007 11:10 AM #2
baka naman noise suppressor? para sa in-car audio ba? kung doon, it should be placed between the power/electric source and the audio unit i.e. your HU.
Usually, noise suppressor's have three wires: red, blue, black. The black is the ground wire. The red wire, you connect to the power source while the blue wire you connect to the audio unit. The power source must be the electrical wire that is connected to the audio unit.
Ten minutes or less DIY job.
June 27th, 2007 12:14 PM #4
between the power source and the amp. Red wire goes connect to the cable/power source, blue wire connects to the red/positive wire of the amp. black wire is the ground cable.
June 27th, 2007 01:02 PM #5
June 27th, 2007 02:34 PM #8
xelpax, depende sa brand, sa wattage - at kung saan. For example, sa Raon eh around 250 petot lang dati ang isang Dai-ichi 75W noise suppressor pero nung dating nag-canvass ako sa Cubao, mas mahal ng 100 petot. May wattage yan: 25W, 75W, 100W, 125W at 150W usually - at least sa mga local brands.
If my memory serves me right, yung Precision Audio brand na noise suppressor sa Concorde Accessories sa SM eh around 1-1.5K.
The Dai-ichi suppressor is actually pretty good. It's square shaped, about the size of have a bar of butter and since flat, pwede mo syang i-mount sa chassis ng car mo or any flat surface undernath the dash using double adhesive tapes. Yung Precision Audio brand, cylindrical ng shape pero di hamak na mas maliit kaysa Dai-ichi. Mas mahal nga lang.
June 27th, 2007 03:14 PM #9
Hmm, since nandito na rin naman 'to. Tanong ko na lang din, kasi may portable DVD player ako, video attached sa LCD ng HU pero ung power source e via adapter nya na nakakabit sa cigarette lighter plug. Pag nakaon ung LCD ko na nakaoff ung player, black na black ung display at crisp talaga, pero once na i-on ko ung player, may parang wave-effect sa LCD, although di naman distorted ung video na nalabas, meron ka nga lang visual noise na nakikita (para talagang alon kung idedescribe). Applicable din ba ung noise suppresor dito? And if ever, mas oks ba bumili ng noise suppresor or bili na lang ako ng power inverter (meaning ung power adaptor na gagamitin ko e ung pambahay) at sa imbis na sa cigarette plug ko ikakabit e ikakabit ko na lang direkta to power source ng sasakyan? And kung mas oks bumili ng noise suppresor, san ko ikakabit?
Sa Raon as of now kasi 400 ung sa suki ko ung noise suppressor. Inverter e 700 for 150 watts. Sensya na maraming tanong, na-curious eh. Hehe
June 27th, 2007 03:37 PM #10
