Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 66
    Galing po sa customs. Eto daw yung mga lumusot sa inventory listings nila. I was supposed to get 3 7450 units kaso naunahan na ako sa 2.
    Originally posted by Ungas
    Yung demo mode ba yung pinipindot yung function switch when the radio is off?
    not sure .. try it.. basta pag naka off yung unit mo, meron demo display na lumalabas... just watch it then may lalabas na "reverse feature demo off" press 6 or 5
    Ok, thanks! Subukan ko mamaya konti. :D
    alrty! let us know kung nag work ;)
    Alternating lights adjusted! :D
    Pag pinindot yung 6 demo function, may lumalabas nga yung reverse feature press 5. Followed the instructions. Nawala nga after waiting for a couple of minutes.
    But when I turn the radio off and press 6 again to check, reverse feature is still "off" same as before. Though the display did not change or reversed its display. Weird?
    Follow up question: (Pasensya na bagito kasi pag dating sa sounds)
    -Pressing the Audio button for 5 secs or more, may lumalabas na pang fine-adjust ng equalizer curve. There are some choices 2N-1N-1W-2W for Low: 40-80-100-160 Hz, Mid: 200-500-1k-2k Hz, High: 3.15k-8k-10k-12.5k Hz. What's the difference if all bands were adjusted to 2W?
    hinde ko na nakakalikot yan ah..hehehehe
    sama mo naman ako sa customs minsan.haha.. anug mura naman nyan
    try switching to see what sounds good to you. The "hz" is the frequency and "N" stands for narrow while "W" stands for wide when boosting or cutting.
    You get to choose if you want to boost a narrow or wide range of frequencies.
    odell::: Di naman ako pumupunta dun, the guy usually calls me then delivers the package straight to my doorsteps. Dun ko lang sya babayaran pag gusto ko yung unit.
    Beefy::: What's the stock settings? Kinalikot ko kasi di ko na maalala yung oe setings, hehehe. Mahina pa pandinig ko sa mga ganyan setups. I don't see any difference with 1N and 2W.
    Di ko alam stock setting.. for sure may madidinig ka na change as long as wala sa -1,0 or +1 yung EQ...
    i got a 7550, the delay in playing mp3's is reduced to 3sec nalang.
    Signature
    ungas,
    anu ba lage dinadala?.hehehe
    boybi,
    panu mo nasabe 3 secs faster siya.?. have u tried the 7450 na?.hehe//
    baka magpalit kasi ako
    yung mga 2003 series ng pioneer mp3 HUs, mas mabilis tlga magbasa ng mp3 tracks. i compared the loading time of a friend's 7450 vs. my 5550 and very noticable yung time difference
    So I should set the EQ to max settings first before fine tuning it? Nasa +2, -1, +2 current settings ko sa EQ.
    odell::: Iba-iba minsan washing machine pa nga yung inaalok or dental chair. May isa pang naka-lusot sa akin dati complete Bose speaker system yung cubes. Mabilisan kasi bentahan nila dun.
    boybi::: Iba na talaga ang may pambili ng bago, hehehe. Mabilis na nga ang 3 secs. etong sa 7450 7secs ang delay pag skip sa mp3 formats.
    di naman kailangan max before fine tune.. usually yung both ends naka (+) tapos yung middle (-)
    Oh ok, so tama na pala yung settings sa EQ ko. I'll test the fine tunings later this afternoon. One more thing napansin ko kulang yung EQ bands ng 7450? Highs nya upto 12.5KHz lang; while other EQs can reach upto 18KHz. Kailangan talagang pag-aralan ito, may hinahabol kasi akong quality sound na parang HT setup. Mala-orchestra ang tunog.
    hmmm masubukan nga yung low (+), mid (-), high (+) na setup mamaya
    Originally posted by odell
    boybi,
    6-7sec daw ang delay sa 7450.
    Signature
    ungas,
    nakakabit na subs mo?. anu amp ginagamit mo to power it?
    Yup, it's up ang running smoothly. I found a RF851X amp to power the subs and separates temporarily. Balak ko dagdagan yung amp just for the subs.
sa mga naka DEH-7450MP: feedback pls..
