I was wondering kung pwede i-series ang 2 relay. Masusunog ba electrical pag ganun? Kung hindi, lalakas ba ang output o parehas lang sa 1 relay? TY.![]()
ang relay po ay parang switch lang po, parang circuit breaker, kaya useless to series it naman.. unless may special purpose...
if you just need a bigger ampherage, just buy high-ampherage relay..
Ah ganun. I always thought na pampalakas ng current ang relay.Dati kasi nagpalit ako ng stock na busina without adding a relay, ayun mahina. Nung dinala ko sa electrician nilagyan niya ng relay para raw lumakas.
a relay is like a secondary switch..pag ni on mo, say, your headlights, mag-o-on ang relay which switches on and then draws its power from a live wire(from battery) to the headlights...parang ang labo ng post ko..antok na
