working or dummy? :D
is this the one installed sa newer accords?Originally Posted by happy_gilmore
around how much and san kaya meron...my power antenna's becoming an irritant already, grrrr!
For the proper operation of a powered antenna, it should only be connected to the ANT line at the back of the HU. Also, the ANT line voltage should change between 12 volts and zero whenever you switch the HU between radio or CD, or between radio ON or OFF.Originally Posted by sauman
For those with an extended antenna whenever the HU is ON, duda ko walang line yung HU para sa power antenna ... or nagkamali lang yung nag-install ... either way, naikabit yan sa REM line para sa external amp, which would explain why the antenna is always extended whenever the HU is ON.
