sirs,
what amps do you suggest for a beginner like me?
i need a 4way about 3K budget na medyo ok na performance n wala static![]()
sirs,
Originally Posted by snker
ok na V12 tol. so-so performance, may sukli ka pa. as for the static, depende sa yan sa pag-iinstall. kung sablay, static talaga. read more about the audio set-up threads, marami ka mapupulot dun.
thnx sir. i heard some models of v12 that are really good.Originally Posted by aceshark
mga sirs, i have a friend who recently bought v12, he followed tips seperating the power source and the rca, but unfortunately me static padin. he even added extra taping to the power for more insulation pero ganun pa din.
i'm starting to have doubts.
mahirap magtiwala sa V12 e...if you plan to upgrade din nman later, better invest on good amps. Kung wala tlaga, v12 tlaga ang bagsak
brad try nyo muna ayusin yung RCA minsan maluwag at may loose contact.I had experienced that also before, nung binalik ko sa LA Accessories sabi nila HU ko daw ang may problema kesyo baka ampli din, but i do it myself and so far ok na ngayon sounds ko malinis na.
Alpine amplifier V-12
Model NV-805
4/3/2 channels biridgeable
OK sa sounds malinis, narinig ko na ang set-up sa Ace hardware SM sta. rosa. Ito bibilhin ko pasok sa budget.
Mga chief, malaki ba ang difference ng 2000W sa 2500W na V12 AMP in terms of SQ? Medyo nakakalito kasi sa itsura, eto ung 2500W:
eto naman ung 2000W:
I got no info sa 2500W, pero sa 2000W, may Super Bass mode daw etc.. Wala bang option ung 2500W?Pero ba't mas maliit ung 2500W sa 2000W model? Pa-enlighten lang po. Tnx! =D
Nevermind... got an answer. Pang motor pa la ung isa. Stupid me... Sensya na po! =D
