Error-11, Error-12, Error-17 and Error-30: this means your disc is either very dirty or is scratched very bad. Either clean the disc or replace the disc.
Error-14: If you get this error, the Pioneer HU is telling you that you have a blank disc. Check your disc.
Error-10, Error-11, Error-12, Error-14, Error-17 and Error-30: this means that there is either a mechanical malfunction on the HU or an electrical malfunction on the HU.
If you are receiving error 11 on your Pioneer mp3 player and there is no problem loading the cd. This means that your lens is damage and you need to replace it around 3.5k php at Pioneer service centers. However, please try to contact your Pioneer service center for further assistance.
i also changed my HU in my hilander xtrm 2000 to pioneer 7550MP last 2003...
at first lagi ko rin na-eexperience yng error-11 sa mga CD-R & CD-RW mp3 discs ko (kc write speed ko 16x, 24x or 32x) ... nakaka bad trip lalo na kng trip na trip mo yng mga mp3s mo tapos mapuputol dahil nag error-11
tapos ginawa ko binabaan ko yng write speed sa lowest speed ng kaya ng cd writer (1x, 2x and 4x) ... and i only now use CD-R discs kc hindi tumatagal ang CD-RW discs lalo na pag nabibilad o naiinitan cya under the sun...
hindi na lumalabas yng error-11 saka hindi na cya nag-skip pag nalulubak ako ...
Sa Pioneer ko. hindi na ko gumagamit ng mga CDRW. ganyan din experience ko. madalas mag skip sa CDRW. Also, might as well use a better quality CD-R or this could harm your Lens as well. Malapit ng mag 2 years itong Pioneer MP3 player ko pero never ko pa nilinisan ng lens kahit minsan at ok pa din naman.
akin deh-7450 din at madalas din nag error-11 o 17, ginagawa ko ino-on-off ko, tapos minsan ok na. ung ibang mp3 din ayaw gumana, sabi nga ng tech e gamit daw ng cleaner, e wala pa ko nabibili. sayang nga kasi bumili ako mung tig 5pesos na cd-r, e ayaw naman gumana sa HU ko, bat kaya ganun un?
From my experience, them P 5/piece na CD-Rs never worked for me. Ang ratio ng ng palplak is nas 5:2 - out of 5 CDs, 2 ang pumapalpak. So now, kung kailagan ko ng cheap CD lang, yung tig-15 na ang binibili ko. So far, okay pa naman lahat, except yung mang mga gasgas na.
also gamitin mo lagi yng standard 12mm cds (same size ng audio cd, vcd, dvd, etc). wag kang gagamit ng 8mm cds (around 160MB capacity) kc once nalubak ka, tatalsik yng cd sa loob & hindi na ma-eject ng player yun
nangyari kc sakin yun, buti na lng nung nag insert ng standard audio cd yng brother ko (kala nya kc walang cd sa loob), pag-eject nya sumama yng maliit. kala ko didiretso na ako sa repair shop
dapat din pala 650MB lng ang ilagay mong mp3s sa cd. nag-try ako dati ng full 700MB and 900MB mp3 cds pero nung nag-play na cya sa mga last songs, puro skip na lng naririnig ko (minsan noise)
kasi sa cdr king ako bumibili.. ung "brick" style oks na oks sa player, e nung bibili na ako, ubos na raw, e nakita ko ung tig 5pesos nga, 50pcs pa naman binili ko,, sayang di ko rin pala magagamit pang oto. kaya next time ung mejo mas mahal sa 5pesos para atleast gumagana...
eh ano po kaya ibig sabihn ng error23. nagtry kasi ako ng cd na may mp3 nag error23 sya tapos sibukan kong magplay ng cd na may wav file ganun din. pareho pong cdr gamit ko. pero pag nagplay na ko ng orig na cd ok naman sya. TIA
pero cd na puro wav files ang laman? talagang hindi kaya i-play ng pioneer HU yan ... i-write mo yng mga wav files mo as "Audio CD", cgurado kaya na i-play yan.
yng mp3 cd mo naman, make sure walang special characters yng filename ng mga mp3s (use alpha-numeric only), also try to limit the filenames to 32 chars only.
gamit kong cds binili ko lng sa cdr king, yng P7 na azul.
