Results 1 to 15 of 15
    Oct 2004
    guys help,meron ako portable dvd,problem wala auxillary input HU ko.May marecommend kyo device para ma input ko audio signal from dvd to HU.meron ako nakita wireless daw kya lang bk di ganun kaganda sound.rule out din thru tape.tnx
    Oct 2005
    try PIE, or yung AUX in cable from pioneer, CB-RB10. I know there is also a generic one. Will cost you about 2,000.00 - 2,500.00 . This is what i used for my lancer to connect my ipod and portable DVD player.
    Aug 2005
    kung walang aux in or IP BUS yung pioneer mo katulad nung sa akin (deh-1450), advice sa akin palit na talaga ng HU.
    pero meron akong nakita sa internet, ewan ko lang kung available dito. check out mo na lang tong website:http://www.installer.com/ipod/
    FM modulator direct connection:
    description: "If you don't see your car listed on any of the AUX INPUT adapters above then this will be your only option. Beggars can't be choosers! This modulator is a direct connect and actually switches your car antenna out of the circuit when you turn it on to help eliminate any unwanted FM interference..."
    hintay ka na lang sa feedback ng mga gurus
    Oct 2004
    tnx sa inyo.tol alam mo price audiovox FM modulator?may nag alok kc sa concorde 1500 audiovox brand daw
    Aug 2005
    Quote Originally Posted by geris
    sorry chong wala pa akong nakikita nyan dito. saang concorde branch ka nag tanong?
    Oct 2004
    concorde southmall,mukha sideline ng isang employee dun.orderin daw muna then sya na magkakabit.
    Jun 2005
    *geris, kung mahilig ka mag D-I-Y at kung may IP-Bus yung pioneer HU mo, you can can make your own auxiliary RCA input using this guide (got this from Kotse Audio Club) :
    1. go to your suki car audio shop and ask if they have a scrap or junk Pioneer IP bus cable and use this guide below to connect a pair of RCA jacks to it :
    if no scrap Pioneer IP bus cable, then you can . . .
    2. connect an RCA cable directly to the IP bus port at the rear of your Pioneer Headunit using this guide :
    HTH
    Oct 2004
    wow galing ah,tnx jaeger!check ko sa wkend HU ko.try ko gawin suggestion mo.
    Oct 2004
    tanong jaeger,saan papasok signal?sa FM radio?in case may nakapasok na wire dun sa HU pinout ok lang ba overlap yung wire dun? tnx
    Jun 2005
    Yung IP-Bus ng pioneer is like your line-in kaya walang signal loss unlike going through the airwaves (FM radio). Dito sa IP-Bus ang connection ng pioneer CD changer or other pioneer units na parang naka-daisy-chain configuration. Pag may naka-connect ka na na CD changer, then use the open IP-Bus of your CD Changer to make the tap. When you press the SOURCE button (on/off) it will just cycle thru all the devices connected to your HU one-by-one as the source of audio signal that your HU will use so if you connect an i-Pod or DVD player to this then the source of audio signal will be your i-Pod or DVD player na naka line-in (not FM modulated source).
    HTH
  11. #11
    kindly elaborate,pls....naaliw ako...may changer ako,e...
    pag binuksan ko ung balot ng ip-bus, tap lang ako sa colored wires na sinabi sa pic, then ok na?
    save ko pic for future reference,h...
    ask ko lang, may 12- and 6-disc changer ako, sa modification na ganito, pwede ko bang ilagay ung 2 kong changer sa isang HU? plus RCA inputs? di ba magkaprob ako sa HU ko?
    kung may complete layout kayo nung IP-bus, pwede paki post nalang din, thanx!
    Oct 2004
    yes same question above,i have cd changer connected to the HU,tap ko nlang ba yung 4 rca wires to the cd changer IP bus mentioned colored wire which is connected to the HU,then ok na?tnx
    Oct 2004
    sir jaeger pls?
    Mar 2005
    pano ko malalaman ang polarity?
    Aug 2005
Pioneer HU,no AUX
