Results 1 to 16 of 16
    Jan 2008
    Good day to all, my ride is a frontier, pick up kaya limited space re installation of speakers and baffles. All stock pa yung naka install at present, HU and speakers. My first step is to purchase a pioneer 2050 hu with 50w mofset and replace all stock door (50watts)speakers with a targa 100watts 2way, lastly for this stage install a pair of tweeters on the dashboard. next step will be the subs, planning to purchase the V12 8" subs with built in amps. para plug ang play n lng s existing set up. Tama kaya ito plan ko, will the pioneer HU produce good quality sounds for the moment hangang wala pa yung subs? TIA
    Apr 2004
    im not a guru but il give it a shot. the pioneer can produce good sounds, but consider separates na lang.
    ang kulang lang is some bass because of the lack of a sub. baka mabitin ka sa 8 inc, baka pwede 12" for bass. but that depends on what kind of box you will use for the sub. slot ported for bayo and sealed for SQ and nice deep bass sound. most people are not too hot on amplified subs, they prefer externally amplified. yun lang, you will want an ampli to go with the sub
    kung kaya pa stretch konti ng budget go for 3050 na para may usb ka na rin. hindi ko sure kung meron ng usb yung 2050 eh. pag meron na ok na rin siguro yan. go for seps na lang sa front, wag mo na isipin yung sa likod. as for the subs, wag mo kunin yung built-in. baka mabitin ka lang pag tagal. mura na lang din naman subs ngayon, straight targa ka na tapos fenton amps.
    sir ok na yung yung high's and mid's mo... sakto for sq lang.
    if your going for sql, then i would say na dont get the v12... kung space naman ang prob, yung friend ko same ride as yours then he got 15" sub and replace the passenger seat with the ported box. yung sinasanadal ngayon kung sa likod ka, yung mismong sub na. wag lang pabayuhin kung may sakay...
    pero if your just for the sq type, get the bazooka na lang. just remeber na walang "umph" yan. its just there to complete the sound.
    Jan 2008
    Tnx for the quick replies mga sirs,
    Mas ok nga sana yung DEH3050 kaso mahal presyo dito s iloilo, yung 2050 nasa 5k na, canvass pa ako kung saan maka mura pa.P install ko na yung Targa na 2way seps 100watts and at tweeters.
    Suggestion po uli, what if yung V12 na ampli na mosfet 4way 2000w, 2,500pesos bilin ko namuna tapos i abang ko sa papagawa ko sealed type na baffles for the sub, may size kaya n sealed type na pwede i lagay sa likod ng sandalan? Targa na 10" siguro kung pwede.
    Yung stock HU n OEM na lang muna(naka cassette adopter naman s ipod kaya claro ang sounds)
    Pwede ba i set up na yung 1 channel ng ampli dun ko ikabit yung 4 n seps targa 100watts at tweeters, then 1 channel for the 10" subs pag na pagawa na.
    sa 4 channel amp, better to use the 2 channel for your separates. then bridge the other 2 for your sub (mag 12" ka na) para walang sisi...go for ported.
Pa comment  po sa mga audio gurus re my plan set up
