Help mga peeps...a cd-r got stuck in my car cd player, pag eject ko ayaw lumabas...tulong naman po...how do i get it out without removing the heat unit?
baka hindi perfect shape yung cd.
actually, yung tip ni ronald ang korek. dahan dahan lang ang bukas. use a tweezer if you have to, tapos, dahan dahan mong hilahin.
it could be that your cd-r is thicker than a normal cd. ganyan din yung sa kenwood ko when i play a certain cd that has a sticker label on top. hirap mag eject yung cd.
eto ginawa ko.
sinaksakan ko ng isang cd. medyo forced it. trying to jog it out of place para sipain ng drive. hindi gumana
next i got the same old cd at nilagyan ko ng isang drop ng superglue. sa bandang edge
tapos dahan dahan ko pinasok hanggang dumikit sha doon sa stuck na cd.
pinabayaan ko ng mga 5 mins (making sure na may contact yung old cd and yung stuck na cd)
TRy to remove power to the HU. Happened to me once (kenwood) and someone advised me to remove negative terminal of the battery for a while then put it back. CD came out when I powered up the HU.
