Results 1 to 11 of 11
    Nov 2004
    Help mga peeps...a cd-r got stuck in my car cd player, pag eject ko ayaw lumabas...tulong naman po...how do i get it out without removing the heat unit?
    thanks in advance!
    wala bang emergency eject "hole" yan gaya ng mga CD-Drives ng computer????
    Dec 2003
    if pioneer wala ata, unless masungkit mo u have to remove the headunit and open it up..baka stuck lng gear
    kapag ayaw pumasok, ibuka mo ng konti yung opening pero dahan dahan lang baka mapunit este masira useful iyang tip na iyan sa buhay :evillaugh
    baka hindi perfect shape yung cd.
    actually, yung tip ni ronald ang korek. dahan dahan lang ang bukas. use a tweezer if you have to, tapos, dahan dahan mong hilahin.
    ronald, hayuf sa tip ah.
    Nov 2004
    thanks for your replies...
    btw, alpine brand ng head unit ko. stock cd player ng revo.
    try ko sungkitin mamaya...pero parang hirap gawin un ah...liit lang ng slot kc.
    mahirap talaga yan bro. good luck and let us know what happened.
    alpine head unit may reset button, try to press with head unit off. then press eject button. yun nga lang u need 2 change all da setting again.
    Jan 2003
    it could be that your cd-r is thicker than a normal cd. ganyan din yung sa kenwood ko when i play a certain cd that has a sticker label on top. hirap mag eject yung cd.
    Dec 2004
    badtrip yan.
    nangyari na rin sa akin yan.
    eto ginawa ko.
    sinaksakan ko ng isang cd. medyo forced it. trying to jog it out of place para sipain ng drive. hindi gumana
    next i got the same old cd at nilagyan ko ng isang drop ng superglue. sa bandang edge
    tapos dahan dahan ko pinasok hanggang dumikit sha doon sa stuck na cd.
    pinabayaan ko ng mga 5 mins (making sure na may contact yung old cd and yung stuck na cd)
    tapos nung tuyo na .. hinila ko na!
    kung kotse kaya ng superglue... cd pa kaya!
    TRy to remove power to the HU. Happened to me once (kenwood) and someone advised me to remove negative terminal of the battery for a while then put it back. CD came out when I powered up the HU.
    Good Luck.
HELP: CD-R got stuck in my car cd player
