Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Apr 2008
    sir, im having problem with my sub... kahapon kase nung nagplay ako ng music bigla nalang ayaw tumunog ng sub ko pero yung front and all meron. i check yung sa channel ng amp. eh may supply naman po. paano po ba magtroubleshoot ng ganito na case and ano kaya ang cause?
    Oct 2008
    i think subs only produce the bass (boom boom boom sound) and no music sa speakers na lang nalabas yung sound/music pati mini basses
    Feb 2009
    nawala ba yung bayo?
    sir hindi kaya nasira na mismo yung subs? over played ba? try connecting another set of subs muna or check kung may power sa wire ng sub to be sure.
    Feb 2009
    Quote Originally Posted by archie123456789 View Post
    tama si archie, gamitan mo ng tester kung ano yung output nung ampli mo kung tama pa ba nilalabas.
    Apr 2008
    alam ko may continuity ang speakers... well sinubukan ko na sa ibang channel using different wire... still wala pa din po nangyari... could be the subs and problem na kase kahit parang jerk sa cone wala eh... sayang naman 6 months palang yung sub.. nererepair ba yun?
    6 months pa lang??? too early to give. wala ba warranty yung set up? kung may power or output pa yung wires mismo, subs na yan. repairable naman yung subs. just make sure na alam ng gagawa yung ginagawa niya. well, come to think of it, depende sa tama ng subs. may iba talagang wala na pagasa. your best bet is to have it checked.
    kasi kung ganyan kabilis nasira, 2 lang pwede nangyari,,, 1. factory defect or 2, mali wiring/rating kaya overload which caused the sub not to work.
    hth
    sorry... double post
    sorry again... triple post
    Apr 2008
    thanks sir archie... i'll try to contact yung binilihan ko ng sub.... all i know is this happend after my long trip around 8 hours continous playing..
    Sep 2005
    sir, check the PIGTAIL. un ung wire na copper from connector to your subwoofer cone. COLD SOLDER po ang tawag doon, though visually nakikita mo nakadikit cya but sa connectors and subs cone mo mahina ang contact nya. all you hv to do is to heat it up will soldering iron kung marunong ka if not baka masunog mo ung surface ng cone.
    Jun 2007
    Quote Originally Posted by danieyoyo View Post
    Sir pls. check the possible caused:
    1) Check mo yung audio aux. in sa sub mo kong may audio signal sya coming from the Head unit, kong wala pls. check the connection bet. Head Unit ( Car Stereo) at sa sub mo.
    2) Check kong may power ang Sub, kong wala check the fused.
    3) Check mo kong ok pa ang mga spkrs. ng Sub mo, spkr. coil, pigtail connection etc. or yong connection mismo ng spkr. at Sub.
    4) kong OK ang connection at may audio signal from Head Unit to Aux. In ng Sub mo at wala parin audio signal sa main spkr. ng Sub mo, ang possible caused nyan may problema ang Amplifier ng Sub mo, kailangan mo ng technician to troubleshoot.
    Yun lang ang ma advice ko, God bless!
    Apr 2008
    salamat mga sir,
    sige subukan ko isa isa yan... update ko nalang kayo mga sir... Thanks
    May 2007
    Check your RCA's cable if the slipped and the 12 volt turn on line. Some amps will report as "powered on" but do not have voltage on the remote line and therefore won't do anything. If you have a digital multi-meter(DMM), Disconnect your sub from the amp and set your DMM to Ohm's. Place the leads on the + and - of your speaker, you should have a reading anywhere from 1 to 8 Ohm's (depending on the number of coils and their resistance). If you get 0.00 or a fluctuating reading, your coil might be burned out. Again, check RCA connections and remote line at the radio and amp. If you have a buddy with a system, borrow his/her sub and hook it up. Check to see if your amp has a light marked "Protection Circuit" and is it on?
    Or MAYBE, Just MAYBE your neighbors got tired of you blasting your tunes all the time and disturbing the peace and quiet in the neighborhood so one of them broke into your car and sabotaged it.
    Apr 2008
    yung may LED light labeled Protection hindi sya nakailaw... ano ibig sabihin nun sir?
    Quote Originally Posted by v6dreamer View Post
    Apr 2008
    nag try ako kunin resistance kanina... sa dulo ng pole yung may clip wala reading na makuha... pero after ng hinang dun mismo sa wire meron na 4 ohms... sinilip ko sa negative na pole mapuputol na yung pagkakahinang mga 3 strands nalang nakakapit! pwede ba derecho hinang ng 40W na soldering iron un? hindi naman heat sensitive?
    Sep 2005
    sir...doon ba sa sinasabi kong PIGTAIL? kung kayang palitan sir pallitan mo ng mas makapal mura lang yan wala pang 100.
    Sep 2006
    mga sir saken may intermitent ung bayo ng subs ko... may power naman then may lumalabas na sound pero ung lakas ng bayo nawawala. ok naman wirings at power. Im using NBN subwoofer ganito ung itsura http://www.sulit.com.ph/index.php/vi...uploadedImages
    nagoogle ko lang ung picture hehehe.... thanks mga master
    Apr 2008
    ok na mga sir napagana ko na, hinang lang katapat dun sa negative na terminal and add na din ng konti pang lead sa kabila for sure... hirap lang ng konti kase hinihila ng magnet soldering iron ko. hehehe..
    maraming salamat
    Sep 2005
    sir next time palitan mo na kci hindi din tatagal yan pagbumayo ng malakas na sunod sunod. what i did is i replace it na medyo mahaba so malaki ang play nya hindi pwersado ung pigtail.
No sound on sub
