Results 1 to 10 of 12
February 8th, 2004 12:28 AM #1
Sirs,
merong problema yung sounds ng REVO namin, nawawala yung tunog ng speakers sa driver side at sa likod din, ano kaya problem nun? loose connections ba? minsan tinaasan ko ng volume kasi isang speaker na lamang natunog tapos biglang tumunog lahat nagulat tuloy kaming lahat, halos mabingi kami.
hoping to hear from you guys.
thanks in advance
February 9th, 2004 06:11 PM #2
Subukan nyo po muna kabitan ng mumurahing speakers kung aling side nagloloko. Pag gumana ito ng tama at hindi nawala, sa speakers ang diperensya.
BANNED BANNED BANNED
- 3,790
February 11th, 2004 09:32 PM #3Open mu yung faulty speaker (driver side kamo) and check for loose wirings.
Or if you can also remove the radio (and from the rear ng radio) e pagpalitin mo yung speaker leads (yung kanan sa left or vise versa) and see if it works. There are some units na hindi puede ito so you have to exchange the speakers from the speaker terminals (you'll have to open the other door and get the working speaker).
Looks to me that you just have a loose connection lang (1st suspect).
2nd suspect is a faulty internal amplifier (expensive, leave it to the pros stuff kind of repair) - call wilson lim na.
3rd possible suspect is a loose ground connection (pero this is a remote possibility) kasi ang speaker terminals are designated - and + and not negative ground. Although baka body ground ng radio ang faulty.
my 2 cents.
April 1st, 2004 06:38 PM #4
rewire ka na lang kung di mo mahanap yung problem and this time get a good set of wires. pero try mo muna yung old speakers mo baka dun yung problem
January 22nd, 2006 06:21 PM #5Originally Posted by wildthing
January 22nd, 2006 11:29 PM #6
Nangyari sa Vitara yan dati. On and off ang speakers depende kung pano naaalog yung sasakyan. Dinala ko sa shop ni Jeff Tan sa Araneta Ave. Ginawa ng dad niya. Expect to spend about Php 350 for the repair. A bit cheaper if you use surplus parts.
- Oct 2005
- 317
March 18th, 2006 12:38 AM #8Originally Posted by OTEP
March 18th, 2006 01:06 AM #9
jeff tan's araneta cars is along araneta ave.. pa-centerpoint bound(bagu dumating ng intersection ng aurora)..
- Oct 2005
- 317
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
