[SIZE=2]I'm planning to upgrade my sound setup from SQ to SPL. I only have a 20K budget. And here is my current basic setup:[/SIZE]
[SIZE=2]Kenwood HU[/SIZE] [SIZE=2]Targa front seps (driven by the HU)[/SIZE] [SIZE=2]Kenwood KAC929 amp (for the sub)[/SIZE] [SIZE=2]JL Audio W3 12" sub[/SIZE]
[SIZE=2]I'm planning to get the Crunch PZi 175.4 4-channel amp to power my targa and sub. Then I'll get some bnew rearfills as well.[/SIZE] [SIZE=2]I'm also eyeing on the JBL GTO75.4 amp or the Hifonics TXi 6406. Which among theses 3 amps is better?[/SIZE] [SIZE=2]I'm confused if I should dispose my Kenwood KAC929 amp or continue using it for the sub.[/SIZE]
[SIZE=2]I'll also get a brand new 12" sub (bebenta ko na kasi ung JL sub sa friend ko) that matches any of the 3 amps I'm planning to get. Any suggestions on which sub to get?[/SIZE] [SIZE=2]Lastly, do I need better rearfills or can I just use the stock and let it be powered by the HU? What is the best way to go here?[/SIZE]
[SIZE=2]To summarrize, here are my options:[/SIZE] [SIZE=2]A. Get a new 4-ch amp to power my targa front seps, get a new 12" sub, use my stock rears powered by the HU, and dispose the KAC929 amp (1 amp system)[/SIZE] [SIZE=2]B. Get a new 4-ch amp to power my targa front and stock rear seps, get a new 12" sub and continue using the KAC929 amp (2 amp system)[/SIZE]
[SIZE=2]Tama po ba to (feeling ko may mali)? Hehehehe! What should I prioritize? To be honest I'm still new to this kind of stuff. I just wanna make sure when I'm gonna the right equipment at maganda ung tunog and satisfied ako sa SPL ng system.[/SIZE]
pwede yung dalawa e
maganda siguro gamitin natin gamit mo
seps - targa ; amp - JBL GTO75.4 or powered by HU (pero better may amp na)
subs - ? (your choice, match mo sa amp) ; amp - your old kenwood bridge mo
syempre para SPL box - ported/ snail/ phat/ ABC/
kahit wag mo na lagyan ng rear sapaw ng subwoofer yan
sa sub suggest ko DD entry level, panalo!! kung may budget pa go higher (but you need to change amp na)
.02
For me JBL 75.4 hindi ka mapaphiya, kahit todo init na yan. DD rin gamit ko yung 1010a lng on a ported box malakas na, pano pa kung DD1012 on a phat box. Around 10+ ang DD 1012 for all I know.
nakupow mahal pala ng DD na 12"... di pasok sa budget... i may need at least 20K for high end 4-ch amp and 12" sub... oks lang ba kung ung stock rears ko powered by the HU?
pwede ganto (20K budget)
seps: targa ; amp - 2 channel amp
sub - DD ; amp - you old kenwood
gastos
DD (entry level) - 10K (estimate ko lang)
box - ported 2K or snail 2,500
amp - 7,500 (pwede kana mag v12 kung di brand conscious or branded na ganto price range)
tapos sukli wires and labor
estimate ko lang
.02
