Results 1 to 9 of 9
    Mar 2007
    here's my side of story...
    i got my relay for the amp/sub... when i turn on the fm station there's a static
    when i rev.??? is there any solution to my problem.... looking forward for your
    opinions... tnx
    the noise is really irritating...
    Aug 2005
    noise suppressor or filter kailangan mo. iniinstall sa power line ng amp or HU nka series ba, dami locally made nyan at mura lang, buy ka ng branded or imported ung local kc small ung wire kaya kanakapus ng power specially kung sa amplifier mo kkabit
    Mar 2007
    tnx san po kaya sir meron ng noise suppressor??? tnx
    Aug 2005
    try m sa mga car audio shop, kung sa banaue ka bka ituro ka sa tabi ni evergoods sa may kaliraya cor banaue kaso locally made lang un, try to find na lang ng maganda na wlang voltage drop at high volume.
    check mo muna kung san mo dapat ilagay noise filter kung sa amp or HU malamang kung generic ung amp e dun siya sir.
    May 2007
    madaming pwedeng cause ng static...
    first try to check the wirings...
    dapat magkahiwalay ang line ng rca at speaker wires sa power line...
    dapat isa nasa left isa nasa right...
    pag gnun pdin try mo mang hiram ng ibang hu pg knabit tpos walang static ibig sbhn sa hu mo may problem...
    try mo din yung scosche ground loop.... sinasaksak lng yun sa mga rca cables para ma lessen or matanggal yung mga static...
    yung mga local kc parang walang tulong minsan...
    san b loc mo?
    kng qc ka daan ka minsan sa shop ko...
    along xavierville ave. audioFX
    Mar 2005
    I-try mo ring mag-parallel ng diode across +tive / -gative ng relay mo. The coil of the relay itself may caused the unwanted static to your FM.
    Mar 2007
    tnx poh mga bossing sa mga advises nyo i'll try to find those things tnx...
    Jun 2007
    Yup dalawa lang naman ata ang cause ng static its either wiring or ung sa saksakan ng HU mo
    dont buy those noise suppressors yet. it should be your LAST restort.
    try what overdrive said...usually the culprit is the wiring.
    separate the speakers rca and the power wire.
need help po sa static
