Results 1 to 3 of 3
    Feb 2011
    Hi fellow tsikot member, I want your opinion regarding the following items for Audio System Update for an 08 Nissan Navara:
    Pioneer AVH-2750BT
    MB Quart FSA 216 Seps
    MB Quart Nano Nan116 Coax
    currently debating whether or not to put an amplifier or not - if so what amp model do you recommend as per the chosen setup above..
    As per subwoofer- also thinking about it..
    Working budget is 25-30k
    Thanks in advance guys!
    Aug 2010
    Quote Originally Posted by rrdanas View Post
    Pioneer AVH-2750BT
    Don't go for a coaxial. Just change the front speakers since I'm assuming you'll be the driver, in most cases. Rather than going for coaxials, I suggest you put the cash in purchasing a subwoofer system instead.
    I will also say that MB Quartz, although prestigious before in the 1990s, has seen its brand power wane due to company mismanagement. Now, MB Quartz is known as a low-mid end brand (dati, it's prestigious enough to be a mid-high brand)
    Pioneer AVH-2750BT
    Feb 2015
    JBL nalang sir
Navara Audio Setup - opinions needed :)
