Results 11 to 20 of 29
DIY to death!
- Jan 2003
- 451
August 30th, 2007 09:47 AM #11Tapos na pala yung project mo, so this may well be moot.
Most relays (well, at least those that I've seen) are rated at 30 amps. If the total current draw of your 2 fans is less than this, then as long as you use the correct gauge wire (read: thick enough) for the connections from battery to the "30" terminal and from "87" to the fans, you'll be ok with just 1 relay.
August 30th, 2007 04:57 PM #12
rion > saan mo nilagay yang 2 fans? for your radiator/ clutch-fan removal and replacement with electric fans?
August 30th, 2007 05:48 PM #13
- Oct 2004
- 278
August 30th, 2007 09:25 PM #14pin 86 should be connected to ground since pi 85 is already connected to positive...
August 31st, 2007 12:48 AM #15
August 31st, 2007 06:56 AM #16
thanks for the Tip. may nakita nga akong website that says this particular relay is enough with two fans. link but I found a extra relay sa garage so dalawa relay na ginamit ko.
it's just a re-wiring on the front a/c radiator with dual fans. including re-wiring of the another fan on the rear secondary a/c radiator.
yung source ng pin 86 that should be negative (first pic) becomes positive when switched on. and my pin 85 line was not intended for a (+)switching line. kaya problema...
peru tapos na po wiring ko. pwede na ba ito? ang hirap na kasi ulitin pa yung switch ko to make it a negative switching type... and my source with the thermostat trigger line is positive kasi eh...Last edited by rion; August 31st, 2007 at 07:42 AM.
August 31st, 2007 12:21 PM #17
ok.. hehehe..pasabit pwede?
kung in an event na switch on mo-pumipitik ang relay, pero yung equipment di nag-function, maari bang sign yun ng busted relay?
Tsikot Member Rank 4
- 2,716
August 31st, 2007 01:09 PM #18
August 31st, 2007 01:13 PM #19
headlight ko kasi ganun,e.... siguro nga relay prob lang..bumili na ako ng replacement..mahal ang original toyota headlight relay,e...
repairable ba mga relay na ganito?
DIY to death!
- Jan 2003
- 451
August 31st, 2007 02:18 PM #20
Xiaomi E-Car
