Results 1 to 2 of 2
- Jan 2012
- 1
January 28th, 2012 12:33 AM #1Guys I just got a new montero and the audio setup is pretty bad so I wanted to change the setup but I'm afraid i might lose the touch screen and GPRS. Did anyone else have a problem like this and does have a solution? Thanks guys I really need the help.
January 30th, 2012 01:05 PM #2
Depending on your budget, you may not necessarily need to replace your head unit. So unless you plan on competing in the local car audio scene, retain your stock head unit and simply install aftermarket speakers, subwoofers, and amplifiers. Hindi mawawala functionality ng head unit mo unless you opt to change it.
high idle RPM at engine start
