Results 1 to 8 of 8
- Feb 2007
- 7
February 12th, 2007 02:41 PM #1Mga Sirs,
Help naman and advice pls. kung ok lang ba na maglagay ng manual switch ang amplifier kase sometimes i used AM radio lang kase sayang ang power.
Thanks
otreb
Unregistered user
- Jun 2003
- 1,121
February 12th, 2007 02:46 PM #2why not just make a kill switch for the woofers ?
because if you manually turn off the power for the amplifier all speakers that are connected to the ampli wouldnt work. this is ideal if you have speakers that are wired directly to the head unit
- Feb 2007
- 7
February 12th, 2007 03:19 PM #3Thank you sir for promp reply,
Actually i try to removed the wire (remote) from amp. then notice na wala na sya power does it mean ba na wala syang power na kinakain? and two speakers na lang ang gumagana yung back speaker, sir ok lang po ba intercept ko na lang yung wire ng (remote) sa ilalam ng head unit and i make switch na lang.
thanks
February 12th, 2007 03:33 PM #4
yup you can put a switch on the remote from the HU to the amp. ganun yung sa lancer ko dati pag ayaw ko paganahin amp kasi may sasakay sa likod at maiingayan lang sa sub i just flick the switch which cuts off the remote wire to the Amp.
- Feb 2007
- 7
- Feb 2007
- 7
February 19th, 2007 10:11 AM #6
February 19th, 2007 04:06 PM #7
paps, ang alam ko, ung remote on ng hu ang nagpapa-angat ng power antenna..so dapat, ung switch, naka-lagay sa wire after ng power antenna mo...para pag off mo ng switch, may power pa rin ung remote on ng Hu mo to power the antenna...bale ang naka-cut off lang, ung remote on ng amp...magulo ba? heheh...
February 20th, 2007 12:51 AM #8
tama si Buraot, mali lang placement mo ng switch, the remote wire sends signals to both the amp and power antena, so trace which wire goes to the amp and insert the switch to that wire.
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
