Results 1 to 9 of 9
    Jun 2005
    mga frendz, tanong ko lang ano magandang set up sa bagong crv? ung sound clarity ang importante pero may konting boom boom. wala kasi ako talaga alam pagdating sa sound set up. hindi ko alam mga brands na maganda. mga around 20k ang budget... ano ba the best na mairrecommend nyo?
    Dec 2003
    hmmm... audition ka sa KAC... kotseaudioclub.com
    Mar 2005
    Quote Originally Posted by mijyet
    go to KAC bro. pero sa 20k not so best na yun for the whole set up. lalo na kung brand concious ka. madamng brands and madaming klaseng amps, subs, sep, etc etc. it all really depends on how much are you willing tp spend for the whole set up...
    Jun 2005
    nagregister na ako sa kac... marami pong salamat!
    Oct 2005
    20k?????????
    Dec 2003
    make it at least 30k para di naman msyadong chipipay setup mo, sayang bnew crv pa naman.
    Sep 2004
    Hi! I own a CRV 2003. In such case same body naman. =) Let me share what I did. =)
    Stock all. I just added two things then so far, for me, nagustuhan ko na yung tunog. Nagbalance out na. Yung stock na speakers natin is shallow basket. So medyo matinis yung tunog. Kulang sa mid. I dont know if same pa din yung speakers na naikabit sa version mo.
    I put a 15" Boston Acoustic sub woofer and matched with a Kicker Class D amplifier na 800 watts. Yung amplifier, linagay ko sa ilalim ng lamesa. Dun sa open space na lalagyan sa ilalim then yung box na 15" sub. Pinagawa ko sya sa TEAM sa may banawe malapit sa Quezon Ave. Malinis trabaho. Hindi tin daga sa presyo. Magandang klaseng plywood din ginamit for the box.
    The whole setup is at around 35K lang. I know may kamahalan despite na walang separates pa. =) Pero ok naman tunog. Balance. Nagkaroon ng semi mid and low.
    Hope this helps.
    Oct 2004
    i own a 2002 crv. Pangit nga talaga midbass and bass nya pag stock. Probably because of the speakers. Kelangan mo parin ng seps at kahit amplified sub at the back ok na. I used the hott setup seps in front powered by a v12 amp. and a ryan audio amplified sub in the rear. Ok na siya if hindi naman sobrang lakas ng bayo habol mo
    Sep 2005
    good day po. I own a 1998 crv and planning to customize my bumper and add some body kits. can you guyz help where to find this shops? thanks..
Magandang set up sa crv (2005)?
