Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    mga peeps,advice namn audio set up na pang low budget lang.. hu is pioneer.. wer and wat maganda set up..
    try contacting JEFFTAN from ClubAE so that he can help you with the sound setup that will fit your budget.
    http://www.clubae.proboards104.com/i...8186689&page=3
    kaso kelangan ka magregister to view the post
    Nag pa estimate ako ng budget meal set up sa banawe for my paj, Nasa vicinity ng P8k to 9k. 1pc 10" sub either targa or kicker es series. 1amp either thunder audio or V12(not sure kung taiwan or china).Plus wirings and box. Baka after holy week na ko pakabit...sana ok kalabasan.
    sir,
    sa akin budget din DIY, 1 12" subwoofer, 2 6.5 seps and tweets, all targa. Plus alpine 705 (japeyks). ok naman tunog (at least for my ears) he he . . . . box and wiring DIY. Details on DIY solicited from the tsikoteers. Galing nila. Subs , seps and tweets kay sir jeff tan binili. Ride is LC.
    Quote Originally Posted by oliver1013 View Post
    Hi, how much iyung Kicker ES? And may 10" sub ba na ES?
    Anyway, kasama na ba sa 8k - 9k iyung seps?
    Oct 2003
    Around 9-10k sounds about right for budget setup w/o HU.
    Ito mga approximate prices
    amp v12 705 2.5k
    sub targa/aura 2k
    seps targa 1.8k
    box depende sa klase 1.5k-3.5k
    wires/install mga 2k
    Feb 2004
    may shop ba si jefftan? saan?
    Sep 2005
    Quote Originally Posted by noel26 View Post
    Sa Araneta Ave yata near Big Berts.
    http://mapcentral.ph/mapcentral/index.cfm
    Type in Araneta Car Accessories, location in Manila
    and there will be a map showing the location. That's Jeff's shop
    It's across the PNB, and Pan De Manila. It's near SM Sta Mesa. And Pizza Hut. You can't miss it. It was fairly easy to find.
    i own a 93 charade,, gus2 ko rin e setup ung sounds nya.. my budget is mga 8-9 thousand cguro.. advice naman po, hnd po kasali ung head unit sa budget.. 12" sana na subs.. or kung my lam dn kau 2nd hand as long as na mganda, hehe.. advice po.. thanks
    Jun 2006
    Quote Originally Posted by ler4_war View Post
    Eto yung contact number ni Jeff Tan and some of his stuff. I have never been to his shop or used his services so can not vouch for him.
    http://www.kotse.com/forums/index.ph...ic=20686&st=20
    Aug 2003
    FOR SALE: 1 pair of 12" earthquake subs with box. 6T. marikina city. txt me if ur interested 09279699199. tnx
    ano po specs nung 12" earthquake subs? is it good... do u hav seps??
    may kakilala ako bnbntahan ako ng 12" subs w/ built in amp v12.. 300 watts.. tapos nakabox na rn.. he is selling it 4k.. mura na ba un or my other suggestions kau??? nid help,,, beginner palang..
    Sir,
    JBL Earthquake series ba ito?
    Thanks!
    Feb 2004
    thanks guys sa info on jeff tan's shop. bihira lang din kasi ako napapadpad diyan sa banda ng manila
    I've seen some listings of people who are selling 2nd hand 12" Targas with an enclosure. You can get a 12" Targa and a box for less than 3k. Try mo sa Kotseaudioclub and check out their classifieds for car audio equipment.
    Since you have a charade, i'm not sure if a big box will fit in your trunk..unless you are willing to sacrifice your trunk space talaga. Do you want boom boom sounds talaga? or are you into more sound quality? You'll probably want a 4 channel amp also, try mo Thunder Audio 4 channels 100watts rms each. bridge channels 1 and 2 for your speakers, 3&4 for your sub. Cost almost the same as V12 amps. But with you budget, you can easily fit a full system in, without the headunit. Go all Targa hehehe. Bang for the buck talaga. Plus you get lifetime warranty. I'm using All Targa as well.
    Napakabit ko na yung set up ko pero instead of targa subs or kicker es, 10" JBL dual voice coil, V12805 amp, vented box and wirings inabot 8K. Ok narin tunog sabi ng kaibigan ko na marunong sa sounds malambot naman daw ang bass. Kaya lang medyo bitin ako parang may kulang. baka palit din ako ng seps para luminaw yung boses. Yan na ata yung sinasabi nila na kinakagat ng upgrade bug...
    Magkano iyng 10" JBL dual voice coil? Kaya siguro bitin kasi stock pa din front speakers mo?
    2800 ata..kasi sa 8k pinackage na lahat..tingin ko nga kaya parang bitin kasi stock...
    Targa all the way! 1 sub, Pair of seps w/ tweets + ABC box + v12 amp = 11,300 !
    kaboom to!! pede rin Clarity basta marunong ka magtono
low budget set-up
