Results 1 to 12 of 12
    Apr 2010
    Help mga sir,, i have dd subwoofer with a 1200 wAtt mono and a 1pc 4channel amp,, at first it was playing good but nung tumagal na napansin ko na hindi na mag kapareho ung bass nya,,would it be necessary for me to have a 2nd battery? what type and brand would you suggest? help nman po mga pro....
    Maybe a big 3 upgrade is needed or capacitor
    Feb 2009
    Quote Originally Posted by johnkeight08 View Post
    dammerung! do your neighbors need to hear your music or your noise? maybe you can turn it a little bit lower or use a headset so your batteries don't run low. if you add another battery or increase your battery capacity, it is mandatory you have to upgrade your charging system too. this will increase your fuel consumption by a little bit. the best way to circumvent your concern is to use headset if you want to blast your ears but do not drive with a headset, it is illegal and is unsafe
    Jun 2006
    This article should help you
    Car Electronic Basics
    And like Jedi said, do the big 3
    Check your wiring and battery terminals connections.
    Im using a 1000w sub. Before masahin sub ok pero nung nagpalit ako ng sub sumasabay yung pagdim ng mga ilaw ko sa pagbayo. What jon aka tsikotshop did nag big 3 sya dahil ok naman alternator ko. Di na ako gumamit ng capacitor.
    Apr 2010
    Mukang kelangan ko tlga big 3 mga boss,, san kya may reliable na mechanic and shop to do this? kc sabi ng audio provider ko mag consider nko kgad mag add ng 2nd battery i doubt it na tuloy prang gs2 lng nila kumita pag katapos ko mabasa ung big 3,,any place or shop you could suggest that i could go to?
    Jan 2008
    most of the time.. grounding lang ang culprit nyan... also check your fuses.. lalo na kung may fuse ka sa battery to amp... minsan yung mga fuse na yan eh akala mo matibay kasi malaki pero pulpol pala
    Please call tsikotshop sir. Si jon po expertise nya yung big3 using pure copper wires gauge 4. 2k to 2.5k po yan. 09053338777
    Jul 2006
    I have no idea on what a "big 3" is, (anybody generous enough to enlighten me?). But it would be worth your while if you can have your alternator checked, and upgraded if you want.
    My ideas
    My ideas
    you can check the article shared by userfriendly sir
    Quote Originally Posted by userfriendly View Post
    Aug 2010
    What car are we talking about? Since if we're talking about midsized or luxury sedans, some of them are already "Big Three'd". Take my Hyundai Sonata for example.. it comes factory stock with 2 of the 3 procedures of the Big Three. I often joke to people in Banawe that I'll need a "Big One" upgrade if I'm to upgrade my electrical system.
    First thing is to check your alternator system. Bale wala ang lahat ng mga improvements mo if your alternator's bonkers.
    If your alternator is healthy, the most cost-effective way to fix light dimming is the Big Three electrical upgrade. This drastically eases the flow of current. Think about water passing through your typical garden hose versus that of a fire truck's hose. Big Three's underlying principle is to reduce the amount of resistance. Most people should have solved their problems at this point, if it still continues...
    Go buy an additional battery. You don't need something big... ilan ba subwoofers mo? 10?. Simply buy those portable ones.. like Stinger's SPV20. Super compact.. kinda like a high school science book. I won't buy capacitor's marketing gimmick and at branded capacitor prices, it's better to add some more and get a second battery.
    You don't need to buy a high output alternator kung 1 sub ka lang.. it's pretty much a waste on the amount IMO.
Lights dimmering when playing sounds?
