Results 1 to 3 of 3
    May 2010
    [SIZE=3] [SIZE=4]ask ko lang po sa mga nakagamit[/SIZE][/SIZE] [SIZE=4]na neto[/SIZE][SIZE=4]ng sub's na eto
    pa post lang po ng feedback kung ok ba ang tunog ng sub's na to thanks....
    [/SIZE]
    eto po ang spec niya->
    • Power Rating: 6,000 RMS, 12,000 peak music power
    • Woofer Diameter: 22"
    • Sensitivty: 92dB
    • Rec. RMS Amplifier Power (Watts): 3,000 - 6,000
    • Frequency response: 17Hz - 150Hz
    • Fs: 16.76Hz
    • Qts: 0.54
    • Vas: 239.1Liter (8.5 ft^3)
    • Voice Coil: 6.5"
    • Xmax: 2.5" (63.5mm)
    • Height: 23" Tall
    • Mounting Depth: 21-1/16"
    • Weight: 369 lbs
    • Magnet Weight: 900 oz (56 lbs)
    • Cut Out Diameter: 20-1/4"
    • Rec. Sealed Enclosure: Net Volume 4.2ft3
    • Rec. Vented Enclosure: Net Volume 8.7ft3
    [IMG]file:///C:/Documents%20and%20Settings/Rio/Desktop/051122_2.jpg[/IMG][IMG]file:///C:/Documents%20and%20Settings/Rio/Desktop/subsJackhammerDimensions.gif[/IMG]
    May 2007
    The 396 lbs 22" JH is a one bad ass Subs. If that sub played you cannot stand in about Ten feet from that subs its like ripping out your whole body. Ive seen one on a hummer and you have stand a least 50' to enjoy sonic of this bass.
    Jun 2006
    17Hz 6kW. Nice numbers. :-)
FEEDBACK ABOUT "MTX JACKHAMMER 22inch SUB"
