Results 1 to 3 of 3
- May 2010
- 143
June 6th, 2010 07:55 PM #1[SIZE=3] [SIZE=4]ask ko lang po sa mga nakagamit[/SIZE][/SIZE] [SIZE=4]na neto[/SIZE][SIZE=4]ng sub's na eto
pa post lang po ng feedback kung ok ba ang tunog ng sub's na to thanks....[/SIZE]
eto po ang spec niya->
- Power Rating: 6,000 RMS, 12,000 peak music power
- Woofer Diameter: 22"
- Sensitivty: 92dB
- Rec. RMS Amplifier Power (Watts): 3,000 - 6,000
- Frequency response: 17Hz - 150Hz
- Fs: 16.76Hz
- Qts: 0.54
- Vas: 239.1Liter (8.5 ft^3)
- Voice Coil: 6.5"
- Xmax: 2.5" (63.5mm)
- Height: 23" Tall
- Mounting Depth: 21-1/16"
- Weight: 369 lbs
- Magnet Weight: 900 oz (56 lbs)
- Cut Out Diameter: 20-1/4"
- Rec. Sealed Enclosure: Net Volume 4.2ft3
- Rec. Vented Enclosure: Net Volume 8.7ft3
[IMG]file:///C:/Documents%20and%20Settings/Rio/Desktop/051122_2.jpg[/IMG][IMG]file:///C:/Documents%20and%20Settings/Rio/Desktop/subsJackhammerDimensions.gif[/IMG]
June 27th, 2010 01:27 PM #2
The 396 lbs 22" JH is a one bad ass Subs. If that sub played you cannot stand in about Ten feet from that subs its like ripping out your whole body. Ive seen one on a hummer and you have stand a least 50' to enjoy sonic of this bass.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
