hey guys i just bought a pair of new 2007 kicker cvr 12's. i have 2 amplifiers but not sure which amp to use. the sub needs 400 watts RMS which is 800 watts RMS for both. audio gurus please help me out?
Kenwood KAC-7252
# two-channel car amplifier
# 170 watts RMS x 2 at 4 ohms (250 watts x 2 at 2 ohms)
# 500 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
# high- and low-pass filters (50-200 Hz, 12 dB/octave high and 24 dB/octave low) per octave)
# variable bass boost with wired remote (0-18 dB, 40-100 Hz)
# MOSFET power supply
# Tri-way capable (Tri-Way Crossover required)
# CEA-2006 compliant
# cooling fan
# preamp- and speaker-level inputs
# preamp outputs
# THD 0.08%
# fuse rating: 40A x 1
# 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
# 15"W x 2-1/2"H x 11-5/16"D
OR should i use this one
Crunch pzi 250.2
* RMS * 4-Ohms: 250W x 2-Ch
* RMS * 2-Ohms: 500W x 2-Ch
* RMS * 4-Ohms: 1000W x 1-Ch
* Dynamic Music Watts
* SEPP A/B-Class PZi Amplifier Designs
* Bridgeable Designs
* Illuminated, Large New Design Crunch Logo
* PZi. MOSFET Pulse Wave Modulated Power Supply For Instant Maxx Current Output
* 2-Ohm Capable A/B Class
* Rugged MOSFET Audio Outputs
* PZi Amp Protection with System Diagnostics LED's That Protects Against:
o Current / Amperage Overload
o Short Circuits
o Thermal Overload
o DC Offset
* Hi-Level Speaker Lead Inputs
* Silver Preamp Level RCA Inputs
* Daisy Chain Line Outputs
* Versa Cross™ Sound Shaping Controls:
o Mono/Stereo Switch
o HP/LP/Full-Pass Freq. Selections (30 Hz to 250 Hz Low-Pass)
* Input Level Control (0.2 to 5V)
* Oversized Speaker Terminals
* THD 0.05%
* fuse rating: 30a x 2
what does THD mean? the higher the number the better? i know kenwood is CEA-2006 compliant but only has a 40 amp fuse(which is about 4-500watts). the kenwood manual say its 1000 watts max. but i dont believe the max of anything just the RMS. i think the specs are more real compared to crunch. the crunch amp has two 30 amp fuses(which is 6-700watts). heard that for every 10 amps on the amp fuse is about 100 watts. so im not sure which amp to use because they both say 1000 watts max but have different size fuses. i like the kenwood because i know they shoud have better quality. on the other hand i think the crunch has more power. i need 400 watts for each sub. please let me know what would be my best amp choice. thanks in advance.
