Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Aug 2003
    guys tanung ko lang my bibilhin kasi akong kicker na subwoofer "12 with box yung box para sa dalawahang subwoofer kulang lang ng isa ok na ba to for 4000 2nd hand slightly use? malakas na ba to? is it true na 2pcs na "12 = 1 solo barric na kicker? :confused:
    Basta tama ang set up mo at marunong ang nag install , it dont have to be malakas na ito or kaya nito phrases . as long as good combo ang subs at amps mo ay guaranteed happy ka sa results .
    always remember , the head unit is the soul of the system but the amplifier is the backbone , if u have a good amplifier , maganda ang reults nito dahil it will sufficiently provide enough power sa subs mo . goodluck sa system mo .
    Aug 2003
    ah ok na headunit ko pioneer in dash, tapos amps bibili pa lang din yung alpine na v12. lam nyo ba kung pano malalaman kung fake yung v12 na ampli? ang sinabi lang kasi sakin e kapag mahaba then my fan sa gitna peke daw yun?:confused: TY
    Ang pagkaalam ko walang lumabas na V12 na amp dito sa Phils. If u want to be sure check perfect circle they are the distributor of alpine in banawe.
    Quick way to find out the real deal ?? hehehe , yung presyo .the real ones should come in a box and a manual , proof of purchase at limited warranty booklet .
    may orig na v12s ata sa mg infinity megamall...8k plus presyo
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    alam ko hinde mahandle nun v12 un solobaric e.. ayaw mo rockford o kaya kicker na maps na lang
    Aug 2003
    odell: kaya handle ng v12 pioneer 2 pcs na solobaric already see it in an altis.
    anyone selling this kind of ampli? pkipost lowest price TY
    SOHC: ok.. just suggesting..
    peace out
    Jan 1970
    meron po pla v12 ang pioneer?
    "is it true na 2pcs na "12 = 1 solo barric na kicker?"
    Nope..
    Jan 2003
    solo barrics are designed to be setup as one. kaya nga "solo".so yes..its something like that. the power of one solobaric equals two. about the amps. just as long as pareho ang wattage ng amp ang subs,effective power delivery won't be a problem. but IMO v12 are kinda weak for kickers, especially solobarics. if it was a compvr then pwede pa. so solobarics, settle for a kicker rockford, or lightning audio. kicker amps IMO are probably the best since they did design the amps for their subs. but all in all its all under the skill of the person setting up the system. IMO Lightning audio is ok for solobarics. if your on a tight budget, get a silicon amp. :D
    Kicker defines Solobaric as a sub that performs like an Isobaric.
    Do you know what isobaric means?
    It is two subs that work together. One sub is wired the opposite, thus not producing the same output as the other but "helps/aids" the other one.
    As one sub pushes air forward, the other does the opposite.
    Research kickers definition of solobaric and isobaric and you'll understand what I mean.
    Advantage of Isobaric loading is smaller box with a deeper bass response. Thus, the term solobaric for kicker subs
    Aug 2003
    guys nkabili na ko ng amplifier na v12 alpine with built in crossover it drives the 2 pc comp vr subwoofer and 2 pioneer oval. Im so happy sa result malakas and maganda yung sound. tanung lang ngayon lang kasi ako ng karun ng ampli i found na umiinit ito pero di naman masyado ok lang ba yun? im planning to buy a electric fan na maliit para sa ampli ko para hindi uminit masyado naka;agay kasi sya sa trunk what do yout think? kasi diba meron yung iba may built in na fan yung peke.
    taiwan v12 yan..
    basta ur happy with what it sounds.. ok na un!
    Aug 2003
    guys tanung ko lang my problema kasi sounds ko ayaw gumana ng subs and rear speakers pati tuloy ampli wala. naka on yung ilaw ng auto-protect ng ampli anu problem nito? help naman.
    Try checking the following:
    1. Is the amp very hot? Baka nag-protect sya coz its getting too hot and not getting enough ventilation to cool itself. Where is it mounted ba?
    2. Are the rear speakers and subs connected to the same amp channel? If yes, check if the amp can handle the load your speakers are presenting.
    3. Just in case na rin, check if the RCA wires going to the amp are not shorted and are firmly connected.
    4. Check the power/ground and remote turn-on leads na rin of your amp. See if there's a stripped portion that's shorting the amp. Check also if the power wire is securely fastened sa battery and that the ground wire is securely fastened sa chassis.
    HTH!
    magkano po 12" L7?
Kicker sub
