Results 1 to 2 of 2
    what madel you guys is good to drive my stock head unit jvc sa strada with jbl front seps and jbl 5inch rear speakers???gusto ko ng branded amps, not the taiwan or chinas because of bad experiences sa hissing sound pag tumagal na gamit mga ganun amps....
    May 2007
    You could isolate Amp. hissing if the ground wire must direct contact with the bare metal of the chassis. Look for an existing bolts that make contact with your car chassis nearest to the Amp. Remove the bolts and scrape away any paint to maintain solid contact with the car body. Your ground wire must not longer than 3 feet and no smaller than 8 gauge depending the power of your Amp and how you plan to use theme.
jbl amp??
