Results 1 to 11 of 11
    Hi,
    Query lang po dito.
    Bigla kc nawawala yung tunog ng sub at rear speaker ko na nakakabit sa amp ko after listening about less than an hour tapos bigla na lang ulit sya tutunog after few minutes.(like 3-5min.)
    I've check the amp and may power naman, but di gumagana yung mga setup na nakakabit dun na speaker and sub.
    Does anybody have an idea?
    Could this be a problem with an amp, fuse or what?
    Hope somebody can assist me
    Thanks in advace
    what's your amp?
    Oct 2005
    check nyo po wirings, baka may loose lang.
    san ba nakalagay?baka masyadong mainit pag ginagamit mo.dapat "nakakahinga" din ang ampi may built in cut off yan pag masyadong naiinitan
    Quote Originally Posted by GlennSter
    yup, tama si glenn. ganyan din sa akin. kapag todo bayo na, tapos mataas pa ang araw... namamatay bigla. cut-off yan ng amp para di mag-over heat. kapag gabi kasi ok naman, hindi namamatay. try mo magpabayo ng tanghali tapos kapag namatay yung amps mo, puntahan mo agad tapos lagyan mo ng itlog. may sunny side-up ka agad. jk lang brader!
    Hehehe,,, :-)
    Oo nga kulang nalang itlog at bacon.... sobra kc init napansin ko kaninang tanghali.
    Anyway, this also happens at night, when i drove from makati to tandangsora.
    I think talagang malakas sya uminit, coz kahit sobra luwag na ng space sa ilalim at sa ibabaw for air ay mainit talaga sya.Khit may fan syang built in ganun parin.
    Do you have any idea,kung ano magandang sulution dito?
    Na iisip ko tuloy kong lagyan ko ng mini fan sa likod! hehe...
    By the way ALPINE 1507 ang gamit kong amp.
    Cheers
    i have the same problem with my set up. i'm using using v12 MRV-F706 amp with built in fan so i don't think its the heat problem. installed subs are kicker cvr. hope you guyz can help me out. thanks
  8. #8
    1. check all the wiring - RCA, remote wire, speaker wire, ground wire.
    2. check if the amps turn on when you turn on the HU, it should be synchronized - if you used a remote wire.
    3. check your ground points. it should be tight. Also it should be grounded on the cars body.
    BTW, how long bago namamatay amp niyo? kasi pag ilang minuto lang tapos namamatay kaagad baka may tama na yung amp. If you have a spare amp, you can test it and see if you have the same prob.
    kung namamatay because nag shu-shutdown yung amp, lessen the gains of the amp. .baka nahihirapan.
    kailangan maganda or rather, balanced yung pag tune ng HU and ng amp para makuha yung optimum performance ng system
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Sep 2005
    baka overloaded yung amp kasi drive pa sya ng rear speakers? bro dagdag ka na lang ng amp na pang subwoofer talaga, para happy na rear speakers mo
    Quote Originally Posted by smalltimer
    hhhhmmmm mukhang overloaded nga ung amp ko. i have 2 twtrs sa front. 2 front speakers, 2 separates tska 2 back speakers hhhhmmmm tpos ung subs pa. . . mukhang ndi na nga kaya nung amp ko. thnx sa info bro. . .
installed setup at my amp suddently get lost
