Results 1 to 13 of 13
    Bros,
    Tanong ko lang kung compatible tong setup ko.
    Eto specs ng seps (ads236dh)
    RMS: 100 Watts
    Impedenace: 4 Ohms
    Max Power : 250 Watts
    Eto specs ng Amp (Sony Xplod XM-4S)
    RMS Power: 50 Watts
    Peak Power: 90 Watts
    Minimum Impedance Bridged: 4 Ohms
    Eto specs ng Sub: (PolkAudio db840 in sealed box)
    RMS Power: 180 Watts
    Impedance: 4 Ohms
    Match ba tong mga to?
    Dati kasi parang ok lang yung tunog. Pero ngayon parang di ko na gusto.
    Kung di match, ano kaya ang dapat kong palitan? Amp? Seps? o Sub?
    Salamat
    robot.sonic
    May 2010
    Quote Originally Posted by robot.sonic View Post
    Bros,
    RMS: 100 Watts
    Impedenace: 4 Ohms
    RMS Power: 50 Watts
    Impedance: 4 Ohms
    Salamat
    robot.sonic
    sir kulang sa power o wattage ng amplifier mo.......
    kaya ang kalalabasan n tunog nyan ay hindi busog.......
    kung titingnan mo sir sa subwoofer mo pa lang
    di na sasapat ang amplifier mo
    sa 180w mo na woofer 50w lang ang papasok n power galing sa amplifier mo
    ang maganda niyan sir magpalit ka ng amplifier....
    at isa pa sir mas maganda kung dalawng amplifier gamitin mo
    isa sa seps at isa sa subwoofer mo.......
    Kulang ang power ng amp mo para sa seps at sub sir. Kung gusto mo yang sony xplod amp mo ilagay mo na lang sa seps mo at bili ka na lang ng mono amplifier mo para sa sub. (Nasasayangan lang sa gears. Hehe.) Or ibenta mo na lang yan at bili ka ng one of these amps
    http://www.mickeysautosound.com/multi-channels.html
    I recommend the Sound Magus C160.
    Functions:
    4X160Wrms Class-AB amplifier.
    2 ohm load stable.
    Double Side PCB and SMD components.
    Adjustable Input level, LPF, HPF.
    Advanced short circuit, overload, over heat and low voltage protection.
    2-channel mode switch available.
    Gold-plated isolation terminals.
    C160 Specifications
    4 Ohm *14.4V RMS Power THD+N <0. 1%
    160W กม 4CH
    2 Ohm *14.4V RMS Power THD+N < 0.1%
    190W กม 4CH
    4 Ohm *14.4V Bridged RMS Power
    350W กม 2CH
    HPF Frequency
    50~500Hz Adjustable
    LPF Frequency
    50~500Hz Adjustable
    Frequency response
    10Hz~25kHz
    Channel separation
    >89dB
    Input Level
    0.2V-5V
    Buffered RCA output terminals
    A Channel
    Operating voltage
    DC10V-16V
    protection
    Short circuit, Over-voltage, Reverse polarity, Thermal
    High-grade Nickel-plated, heavy duty terminal block type connectors
    Yes
    Isolated, gold plated speaker and power terminals
    Yes
    Dimension(mm)
    53x228x347mm
    Or you could buy a JBL amp.
    PS: Hindi ako connected with mickey's autosound neither sound magus and JBL. Hehehehe.
    Kahit hinde ako nagpapatugtog ng malakas bro kailangan ko ba talaga mag upgrade ng amp?
    Plano ko pa naman sa december mag upgrade ng Polk Audio db6501 na seps.
    Hmmmm.... Baka may interesado dyan sa sony xplod xm-4s. Benta ko ng murang mura.Bentang adik!
    Jun 2009
    mas mataas dapat ang wattage ng amp kesa sa speakers and subs para laging busog di nagaralgal
    Pag mas mababa kasi wattage ng amp . at mataas ang sa speaker hirap ito at madaling mag init amp. at hindi maibibigay ang magandang tunog ng speaker.
    hay... kailangan na mag upgrade. Gastos.
    hmmm... nice seps you have there robot.sonic
    yung front seps ko; 80W nominal, 160W max input
    driven by a 4x50W RMS rockford fosgate amp, MBquart seps rear * 75W nominal, 120W max
    within tolerance/safe range pa naman sila and both sounds great, though i know na mas may ibubuga pa sila kung mag-upgrade ako ng mas powerful na amp para dito, busog sabi nga nila and it's true...
    btw, there's no such thing as overpowered speakers(as a lot of people think ed of)... mas masama pa i you are cranking up your speakers with an underrated/too low wattage amp, result; speaker damage
    need help mga sir! same problem din. i have a alpine old school amp 3523 40watts x2, gusto ko sana gamitin sa targa seps x652 ko. ok lang kaya yun? thanks!
    Aug 2010
    I wouldn't recommend trying to breathe life into used amplifiers. Eventually, you'll have to replace them. So I'm a no on that.
    but is it ok or underpowered?
    Aug 2010
    Di ko alam kung ano yun RMS power ng Targa eh. But at 40Wx2, dapat kaya. If not, sakto lang. It might be a better idea to use the HU to power it though.
    May 2010
    Bros,
    RMS: 100 Watts
    Impedenace: 4 Ohms
    RMS Power: 50 Watts
    Impedance: 4 Ohms
    Salamat
    robot.sonic
    sir depende po iyan sa ohms ng speaker mo na ikakabit sa amplifer mo at depende din po iyan sa pagkaka wiring mo kung ito ba ay series o parallel wiring ang gagawin mo...
    for example po sir kung ang amplifier mo ay mono block 300w RMS at 8ohms
    ang power output
    at kakabitan mo ng dalawang subwoofer dapat ganito ang babagay na specification ng woofer jan.... dalawang 150w RMS at 4 ohms na woofer at i-series mo ang connection
    pag nag series ka kasi ng dalawang woofer na 4ohms ang total ohms nun 8ohms
    at pag nag parallel connection ka nmn ng 4ohms ang total ohms nun 2ohms nmn
    sa ohms po yan unang tinitingnan sir para ma compatible ang RMS watts
    yan po sir diagram para mas malinaw hehehe
Compatible ba?: 100W RMS Seps powered by 50W RMS Amp
