Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    Oct 2015
    Guyz, what can you suggest on my HU? It only has AM FM, AUX, rear cam, ipod/ usb port... But on the manual it has more features,though in actual its not there.
    Now, I would like to add some features like Bluetooth, Tire Pressure Monitoring System, GPS..., which are on the manual.
    1. Do you think I should ask the dealer to add them for free coz its on the manual?
    2. What might be advisable to do so, replacing the entire HU, which has all the features mentioned above?
    3. Or Could IT BE be better if I BUY the portable ones and remain the HU especially GPS And TPMS? ... ( there are some spare buttons which can be used)
    3a. If u advise just to buy portable GPS and TPMS, WHAT brand do you recommend?
    4. But how about the Bluetooth Audio?...(this is not on the HU) what should I do?
    Thanks in advance...
    Jun 2012
    Bluetooth - Bili ka sa cdrking ng saksak sa aux, bluetooth na sya
    Gps - stand alone gps cost 6k sa winterpine. Winterpine prefer ko dahil maganda map nya. Pag may overpass at underpass papakita nya talaga saan ka papasok. Di lang basta basta sabihin na diretso lang
    1. Di porket nasa manual, your car will have it. Pagtatawanan ka lang ng dealer for even thinking such. The manual is a general document used by Lancers all over the world, obviously each country has different spec levels.
    2. The Rockford Fosgate system in the Lancer GT-A focused on sound quality rather than fancy toys like GPS and Bluetooth. You can replace the HU with an aftermarket unit, but make sure it can support your Rockford Fosgate speakers and subwoofer, as well as the steering wheel audio controls.
    3. You can buy aftermarket TPMS systems, around 15k. You can also buy GPS systems, but I'll recommend that you just get a smartphone with a data plan and use Waze/Google Maps.
    4. No choice on Bluetooth unless you change HU.
    Oct 2015
    Quote Originally Posted by dct View Post
    i'll try the cdr king... Hihihi... Meron nmn akong RCA cable for Aux.. Kaya lng messy tingnan...
    Winterpine? Saan po un??
    Eh ung garmin at AVT kya?
    Ayos na ayos nga ang sound quality ng rockford... Satisfied... Medyo malapit sa bose speaker ko sa bahay...
    Mas okay ba pag may TPMS?how accurate they are? Or should i use only the tire gauge checker which is 230 pesos lng? Though mas masaya kapag automatic... Di n lalabas para check 4 tires..
    Nasa sayo yan kung gagastos ka 15k para lang hindi ka na bumaba ng kotse para magcheck ng tire pressure.
    Oct 2015
    Pero reliable ba TPMS? and accurate? May alam po ba kayo n brand n maganda?
    Jun 2012
    Quote Originally Posted by khenma0928 View Post
    Winterpine = avt. Mas ok para sakin ang avt kaysa garmin
    Digital TPM systems aren't always 100% accurate, but they work when it counts - you'll find out right away when you have a sudden drop in tire pressure due to a puncture.
    However, any driver with a fair bit of experience can easily tell if they have a flat. You don't need an expensive device to tell you that. Also, regular tire pressure checks at the gas station (weekly or monthly when you fill up) is enough to keep your tire pressure in the right range. From experience, I only lose about 1-2 PSI after about 3,000 km (1 month worth of driving for me).
    If you still wanna spend a significant amount of money on a TPMS, your best bet for your Lancer is Winterpine, Mitsubishi's accredited 3rd party accessories supplier.
    Jun 2012
    Oo nga sobrang mahal. Once a month kapag magpagas ka, isabay mo check ng tire pressure. Tip 10 pesos kada pacheck sa gasoline boy
    Oct 2015
    Thanks for the infos. Maybe ill check them by manual gauge...:-)
    Sa GPS fone n nga lng gagamitin ko... Need to buy nlng smartphone holder...
    Last week plng ako nagpacheck since binaba ko ung pressure from 48 to 32... Tinip ko pa nmn ay 5pesos per tire... Haha digital ung inflater nila..
    Cdr king b Bluetooth mo? Hahaha..
    Aug 2011
    Go to winterpine araneta sir
    I'd suggest getting a Mountek Snap+ for your phone holder. Looks very neat with no need for suction cups. Around 2k in OLX.
    Jun 2012
    Wala ako bro. Alam ko lang na may ganyang device. Meron rin sa lazada
    Aug 2012
    Yung 48 PSI mo ba ay cold tire pressure or hot tire pressure (nagamit na yung car)? 32 PSI should be cold tire pressure. You should check first thing in the morning before using the car.
    I never needed TPMS dahil may digital tire air pressure gauge ako. I check once or twice a month lang or before a long trip. Meron din akong tire inflator so sa bahay lang ako nagfi-fill ng air. I lose 1 PSI per month which is normal.
    Quote Originally Posted by red_one View Post
    48 PSI was the tire pressure when the tire came from the factory. Lagi naman talagang sobrang taas nun, and you should really adjust it as soon as you get the car.
    But after that, tire pressure doesn't really change much so there's nothing to fret about. Naghahanap lang ng pagtatapunan ng pera si TS, sana sakin nalang ibigay. 😁
    Jun 2012
    Hahaha natawa ako sa pagtatapunan ng pera.
    Gawin na lang evo look para cool ka sainyo
    Oct 2015
    This is magnetic right? Indi ba makakasira ng fone?
    Jut was correct...48psi was the pressure when we take it from the casa... Which i really wondered why it's over the recommended in manual and on tires..
    Yan na next project ko... Evo... Pero bakit ung sa hood puro CF yta?? Pede b syang ipa body paint
    Nope. Phone's have flash memory which are unaffected by magnets. I've tried the iPhone 4S, 5, and 6 as well as the Note 4 & 5 with no issues at all.
    Evo conversions are too tacky IMO. Kahit anong gawin mo, your regular Lancer EX just isn't as wide as an Evo X.
    Also, if you buy all the proper kits (instead of those cheap knockoffs), mahal din. Sana bumili ka nalang ng Miata, mas pogi pa.
    Well, pera mo yan, kung gusto mo ubusin lahat para feeling mo cool ka ok lang din naman. 😊
    Oct 2015
    Miata?? Yun b ung top down?
    I like how evo looks kase
HU of Lancer ex.... Rockford Fosgate 710 W featues
