Results 1 to 6 of 6
December 13th, 2005 10:40 AM #1
help naman peeps. my HU (DEH 3750MP) resets when turned off. what's the problem? thanks in advance.
December 13th, 2005 03:54 PM #2
Have your wirings re-checked. AFAIR, Pioneer HUs have a cable (it used to be colored light blue or something in that hue - at least in my old KEH HU) that you need to connect to either the car battery or to where the in-dash clock is connected. This "blue wire" essentially provides power to the..."memory module" of your HU so that your HU would "remember" it's settings everytime even though you shut-off your car.
jagxtrm GuestDecember 13th, 2005 08:31 PM #3
alam ko standard yng color coding ng cables ng pioneer head units. yng sa pioneer 8650 ko color yellow na thick cable yng steady power with 10A fuse and filter (direct from battery or pwede sa isang fuse na steady power).
meron naman cyang red cable na naka-tap sa ignition/accessory switch.
yng blue wire ko naman naka-tap sa panel light, para kng nag turn-on ako ng park lights, nagdi-dim yng display ng head unit.
bka both cables naka-tap sa ignition/accessory switch kaya pag-off ng switch, nare-reset ang settings ng head unit.
December 14th, 2005 03:00 PM #5
the HU resets when you turn IT off or when you turn the IGNITION KEY off? if it's the llater of the two, it's definitely your wiring. have the shop that installed the HU redo the wiring for you since they're the ones who botched it up. but if you prefer to DIY it: yellow is the constant 12volt lead, red is the switched 12volt lead. get these two wires right and your problem should be solved.
Traffic!
