Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
    Oct 2015
    +1 ako dito. The Evo is not about looks. Everything has a purpose. It has holes for cooling. Its wings and body kits help it stick to the ground.
    Pansin mo sa picture may umbok sya over the rear fenders? That's to accommodate the wider track. The front fenders are also wider. You can't do that cheaply on a stock EX.
    Holes in the hood will let water drip on your engine. The real hood is aluminum and has rain channels. Again not easy and cheap.
    I can understand the need to look maangas. We all went through that stage. After a while though you will realize that all show and no go won't fool the people that matter.
    Keep it simple and clean. Nice rims and a bit of lowering go a long way.
    I was thinking about to change for the hood because of cooling nga...but to be looks like that....kasi pansin ko mabilis uminit engine ng 2.0... And the temperature easily rise up into half in just a minute or two.
    why is that so?
    But yeah, what about the water.. It could pass through the hood and wets the engine.. Is this a treat to the engine?
    I like the rims too.. That's why im preparing for it.
    Aug 2004
    Engines are designed to warm up fast. The thermostat does not allow coolant to circulate until the engine reaches its operating temp. Those hood holes won't help.
    Oct 2015
    So it is just normal that its on the half of thermostat... Even though i change my coolant? My SA told me to use 50/50 mixed coolant from shell only....
    Oct 2015
    Q: Standard po ba size ng head unit na may touch screen panel?
    Gusto ko sana magpalit ng touchscreen panel HU ng lancer for additional features like gps Bluetooth etc. (knowing that it could void the warranty.)
    Anung HU brand ang reliable and durable which could lasts into 10 or more years...and ofcourse ung compatible sa Rockford Fosgate...?
    THANKS....
    F.Q.: (Though not in the right section,)
    Neon lights po b ung nilalagas sa ilalim ng dashboard?? And mahal b mgpalagay nun?
    Aug 2012
    If it is similar to Rockford Fosgate HU of Mitsubishi ASX, then it is standard 2DIN size. Many good brands out there, Pioneer, Alpine, Kenwood, etc. Just pick your own poison.
    Oct 2015
    Quote Originally Posted by red_one View Post
    this...po....same lng po kaya? 2din?
    Aug 2012
    Quote Originally Posted by khenma0928 View Post
    Yup, 2DIN size lang din yan.
    Oct 2015
    Ok thanks po...
    Edit: any 2DIN will be compatible with Rockford Fosgate speakers and amp??
HU of Lancer ex.... Rockford Fosgate 710 W featues
