im a beginner with audio setup. just got myself 2 8inch subs for a lesser price, but it seems that bass sounds flat and soft.
would wish to have one solid...rocked...hard pumping bass.
need help..tnx
need help..tnx
sir baka nasa sub nyo po talaga ksi meron mga bass na soft talaga ang bayo IMO mas maganda ang mga soft na bumayo mas masarap sa tenga..
Try nyo galawin yun HU nyo yng bass freq kng meron try inc and decreasing tingnan nyo kng san sya tumitigas tas lakas mo yng sub level yun lng naman po un eh. hope it helped u...
yep.sa HU lang siguro yan or sa subs na nabili mo. meron dapat control sa bass yang HU mo. kahiot tape deck HU meron e.
Do you have an amp for your subs? At what settings do you have it on for your subs?
I kinda like my sub pounding soft with slight hardness. that Tog Tog sound. If its too hard..it doesnt sound like music anymore. I start soft..starting at 30hz..then i work my way up slowly until I heard some "Tog tog!" then I turn it up a little bit more. And that's where I usually like it.
Based on my ears, one 12 inch sub eh talo yang two 8 inches. Anyways, dami ring possibilities, like:
Box type (slot, ported, abc? include dimensions as well)
Tono (might check the amp kung meron at baka naka-HPF ung sub mo, also, try increasing the bass gain more than your speakers if you want the solid bass, kaya lang less masakit sa tenga pag masobrahan)
Subwoofer type (as mentioned above, may iba talagang soft ang tono ng bass)
etc...
ah..ganun pala yun?hehehe..pero try ko na rin icheck for myself..ano ba mas cool tingnan 2 8' subs or 1 12' lang without compromising the quality?
Bosing noel di ko pa kasi hilig ang trunk layouting eh (nagpipigil sa gastos. haha), pero re:cool looks, ika nga nila "kanya-kanyang taste yan." Pero saken lang mas oks ung 1 12 inches sabay abc box. Ung sub ko sa isa kong tsikot Aura lang eh, pero oks ng tignan kahit di mo na lagyan ng grill. Simpleng swabe lang.![]()
mga sir, check nyo itong site na to:
http://www.decware.com/dbk10.htm
sa mga interesadong gayahin, pwede ko kayong ipagawa sa mga marunong gumawa. pm me.
hindi ba depende sa music din na pinapatugtog yan? i mean may hard pounding music. imo i like yun bass sound na gumagapang yun sound... ahehehe...my old car used to have 2 16 inchers 500 watts each powered by a kicker 1000 watt amp.. matigas yata yun sib ko nun e pioneer yun parang metal design... well its gone na... i miss it tho...
Sub positioning could also be a factor. Whether you rear or front fire it. Rear in most sedans are better. But, I have mine front firing now with rear seats down. I'm just experimenting with different positions. In my experience, front firing, seats down, windows closed...You can't feel the bass outside. But rear firing,seats up, windows up, you can feel the bass. Front firing with windows down..thats a whole different story, you can really feel the bass and hear it outside.
Just play around with the amp settings, til you get your desired sound. But, it also could be your amp or your subs limiting the sounds you are looking for.
*Gerard
Tama ka bro. Depende din sa music. If I play some rock songs, I hardly get any bass. But when I put on my cdr full of hip hop music/rap/r&b, that's when I feel it.
1 factor nga ang recording ng music, may talagang malambot without the
help of crossover meron namang kahit anong baba na ng freq matigas
talaga. much better kung may crossover. the rest bass - mid - treble
control na lang.
You can try the following:
1. Get a good box. Make sure edges are sealed so air does not escape.
2. Give your subs plenty but not too much power.
3. Make sure your phasing is correct.
4. If you can, put the sub and box in the front of the car.
5. Since you have 8 inchers, if you can, put them in the front doors and sound deaden the hell out of your doors.Hard to do but will give you one heck of a customized system. This will only work if your subs can run as free air subs.
6. Set your gains properly.
7. Set you crossover points correctly.
OT:
pinapalambot pa ba yung mga speakers/subs kapag bagong bili?
parang run-in?
based on my audio gurus here:
hard pumping bass depends on:
the specs of ur sub(s)
the type of box - usually recommended snailbox for streetbase
the specs of the amp
genre of music? hehe rnb / hiphop?
the specs of the HU and ksama rin ata un settings sa HU - db "decibels" mid-low-high..sub lvl- mga ganun...
umm correct me nlang if im wrong... newbie rin ako e :D
wala ka dapat aasahang bass sa rock music. kung magtetest, dapat hiphop, rnb or rap. try "im in love wit a stripper".
