Results 1 to 11 of 11
    Sep 2006
    guys help nman po..reinstall ko ung car stereo ko which is deh-2050MPG kc nwawala ung memory but when i turned it on nag open nman sya kso nka MUTE na sya...is there any secret or any thing para tumunog sya?pls po help..salamat po sa inyo..
    Nov 2007
    sir nakakabit ba yung yellow wire sa possitve kasma ng red wire?
    Sep 2006
    * aga...sir thanks sa quick reply....sinunog ko lang ung dati nyang wirings tapos me filter sya na square na with input/output wires red yellow and black.what ived did is pinagpalit ko ung supply nya ng red and yellow kc nawawala ung memrory tapos wen i turned on ayun nka power sya pero nka MUTE....sir dapat ba pagsamahin ko ung yellow(memory) and red (acc)?and tangalin ko na ung filter box din?thanks po ulit..hope to hear from u guys.
    Quote Originally Posted by aga_cruz View Post
    Sep 2005
    red should go with the ignition...pag off ung key off din ang HU mo. then yellow should go on the live positive source so the memory will stay even the key is off.
    P.S.
    I thought bibili ka na lang new HU?
    Jun 2006
    baka naka-protect mode sya?
    sa mga Home theater recievers kasi like Harman Kardon, pag may mali sa wirings, it goes into protect mode para di masira. Wala din sound.
    Im not sure, pero baka lang meron syang advanced feature na ganyan.
    Sep 2006
    guys...me power nman sya kso when i turn it on me ilaw lahat..pero nkalagay sa screen MUTE..FYI tulong po..
    Quote Originally Posted by tucker_2ph View Post
    Nov 2007
    sir pagsamahin nyo po yung red and yellow then connect nyo sa positve ng batt
    Sep 2006
    * aga....sir pinagsama kna tpos bypass kna ring ung filter box nya ganun parin MUTE pa rin lumalabas sa displays na..having a hard time to look at the net ng manual..thanks po ulit.
    Nov 2007
    btw sir may natatago pa ako manual ng pioneer stereo model 1150 MPG, sa tingin nyo pareho lang ba yun ? hindi naman kaya naka mute lang sir?
    Sep 2006
    this is what happened...nawawala ung memory nya when it turned if off umaandar pa sya that time..so i decided to reverse the supply baliktad kc tapos pag ON kna nkita ko nag open naman sya me power kso nka MUTE..parang na lock sya i dont know.try ko rin ibalik ung dati nya ganun pa rin tried ko ung pinagsama ung RED and YELLOW same result..nka MUTE pa rin nkikita ko sa screen.hay..anyway try ko rin mag research ng manual..sana me makabasa din na meron gantong model..thanks again sir aga for the inputs.
    Sep 2006
    pki tignan na rin sir how to remove sa mute ano key to press.thanks po ulit
help..pioneer 2050MPG
