Results 1 to 10 of 11
- Sep 2006
- 13
April 4th, 2009 04:17 PM #1guys help nman po..reinstall ko ung car stereo ko which is deh-2050MPG kc nwawala ung memory but when i turned it on nag open nman sya kso nka MUTE na sya...is there any secret or any thing para tumunog sya?pls po help..salamat po sa inyo..
- Sep 2006
- 13
April 5th, 2009 02:53 AM #3* aga...sir thanks sa quick reply....sinunog ko lang ung dati nyang wirings tapos me filter sya na square na with input/output wires red yellow and black.what ived did is pinagpalit ko ung supply nya ng red and yellow kc nawawala ung memrory tapos wen i turned on ayun nka power sya pero nka MUTE....sir dapat ba pagsamahin ko ung yellow(memory) and red (acc)?and tangalin ko na ung filter box din?thanks po ulit..hope to hear from u guys.
- Sep 2006
- 13
April 5th, 2009 05:35 AM #4
April 5th, 2009 10:22 AM #5
sir pagsamahin nyo po yung red and yellow then connect nyo sa positve ng batt
- Sep 2006
- 13
April 5th, 2009 12:25 PM #6
April 5th, 2009 02:06 PM #7
btw sir may natatago pa ako manual ng pioneer stereo model 1150 MPG, sa tingin nyo pareho lang ba yun ? hindi naman kaya naka mute lang sir?
- Sep 2006
- 13
April 5th, 2009 03:27 PM #8this is what happened...nawawala ung memory nya when it turned if off umaandar pa sya that time..so i decided to reverse the supply baliktad kc tapos pag ON kna nkita ko nag open naman sya me power kso nka MUTE..parang na lock sya i dont know.try ko rin ibalik ung dati nya ganun pa rin tried ko ung pinagsama ung RED and YELLOW same result..nka MUTE pa rin nkikita ko sa screen.hay..anyway try ko rin mag research ng manual..sana me makabasa din na meron gantong model..thanks again sir aga for the inputs.
- Sep 2006
- 13
April 5th, 2009 07:14 PM #9pki tignan na rin sir how to remove sa mute ano key to press.thanks po ulit
April 15th, 2009 04:16 AM #10
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
