Hello po mga bossing, ano po ang magandang sound setup sa b2200 na double cab? nag tanong ako sabi nung nag sesetup v12 and 15" na kicker speaker lagay nalang daw sa gitna ng driver seat.
that the only place that you can put subs in that pick-up, walang space sa back of rear seats. but 15" is too big for the space between the drivers seat, or it might fit but the box size is small for the requirement of the sub.
gitna ng driver seat meaning sa harap tapos 15" yung kicker na gamit mo. di yata kasya yun ang laki masyado ng box ng kicker. pag niliitan mo ang pangit ng tunog. try mo yung S8L7 mas maliit yun. we have 2 options na pareho ko na natry. 1st is remove the front passenger seat and place your 15" kicker in front para di masacrifice yung box size. the 2nd one is just place it on the rear seats para may makakaupo pa rin sa tabi mo.
Originally posted by Rolandml Hello po mga bossing, ano po ang magandang sound setup sa b2200 na double cab? nag tanong ako sabi nung nag sesetup v12 and 15" na kicker speaker lagay nalang daw sa gitna ng driver seat.
Maraming salamat po.
Roland
teka naisip ko lang.... may cover ba yung trunk nung pickup mo? baka pwede sa bed mo na lang ilagay yung subs mo. kahit mag 4 na 15" ok lang
Meron na akong setup galing sa car ko dati... yun lang 2 na sub lang tapos 10" naka lagay sa likod problem lang di ganon kalakas pag nasa loob kana... oo meron syang takip gator cab
Bro, setup ko ngayun yung pickup ko but it's a mitsubishi. What I did is create two boxex that will fit under the two front seats and that is for the separates. Tapos a custom built box that will fit at the back of the rear seat, bale dalawa 8" subs ang kasya. That's the biggest na pwede eh. OK naman yung bass ko pero syempre, better bass response pag bigger yung sub.
Hope this will help bro.
BTW, I make my own box kaya na-cuztomize and nai-fit ko sa rear seat.:D :D
Originally posted by broom!broom! Bro, setup ko ngayun yung pickup ko but it's a mitsubishi. What I did is create two boxex that will fit under the two front seats and that is for the separates. Tapos a custom built box that will fit at the back of the rear seat, bale dalawa 8" subs ang kasya. That's the biggest na pwede eh. OK naman yung bass ko pero syempre, better bass response pag bigger yung sub.
Maraming salamat po... try ko kung kasya ang 10" na sub
pwede ba 12" na solo sa gitna ng rear seats na kakasha pa rin 2 passengers sa likod? i heard di kelangan ng malaking box ng solo's.. kung i-customize yung rear seats na tanggalin talaga yung gitnang part ng seat para gawing sub enclosure na pwede na ding arm rest.. tapos 2 8"solo's sa space between the driver and passenger seat..
ganito kasi ang plano ko. Ang kailangan ko improve sound quality lang sa current setup.
current setup:
HU = pioneer 1650
Front speakers = philips coaxial (stock)
Rear speakers = none ( sira na kasi eh )
ok naman yung tunog masaya naman ako dito pero palitan ko yung mga speakers kasi nasira na din yun ne-repair ko lang. tapos since 85 to 20Khz lang ang response ng coax dag dag ako ng sub par umabot man lang ng 40 - 20Khz.
planned
HU = pioneer 1650
Front speakers = targa coaxials stock location or as suggested by caloyski and others seps na targa din
Rear speakers = targa coaxials.
subs = targa 8"
amp = for sub
i-drive ko lang yung fron and rear speakers ng HU yung subs lang ang idadaan ko sa subs.
so mahina lang siya pero maganda naman ang sound quality plus mura. Madami pa kasi ako project eh. most are not car related.
most probably you would need a 4channel amp to power your front speakers and your sub. yung rear mo pwede na powered by the headunit nalang. hindi ko kabisado mga models ng v12 e. intay tayo ng ibang reply.
ako ang plan ko is to imrove lang sound quality nung current set up.
ang original plan ko ay.
palitan ko lang ng targa seps or coaxial yung front tapos yung rear lagyan ko din ng coax.
kung mura lang naman yung subs na 8" plus v12 na 60 to 80W 4ch or 2ch bibili na din ako...assuming mura lang naman kung hindi upgrade ko lang yung stock speakers ng new set ng targa
punta ako sa dai-ichi kanina sa megamall. meron ako marami ulit questions
base sa budget ko na kakapirangot eto mga question ko.
1. alin masmaganda sa front speakers pioneer na coax or targa seps
targa seps xseries yata 1500 yung price pinakingan ko ok naman kaya lang hindi ko ma compare sa low end na pioneer. as per specs pareho lang naman.
2. alin mas maganda fenton na 2ch para sa bus or V12 na fake.
yung fenton 2x100W 3200 ang price sa megamall.
