Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Apr 2005
    chiefs and chiefesses
    i need your help in determining what amp to use with these subs that i have with me.
    specs of the subs are as follows:
    Subwoofer Specifications 12IB4
    Fs (free-air resonance): 40.5 Hz
    Qts (total speaker “Q”): 0.634
    Qes (electrical “Q”): 0.673
    Qms (mechanical “Q”): 10.967
    Vas (equivalent compliance): 3.97 112.4
    Xmax (linear excursion one-way): 0.288 7.3
    Effi ciency (1W/1m)*: 92.2 dB
    Sd (effective piston surface area): 78.5 0.0506
    Re (DC resistance): 6.07 Ω
    Znom (nominal impedance): 8 Ω
    Pt (continuous thermal power handling): 125 Watts
    Wired directly to the amplifier:
    A single 8Ω speaker will present a 8Ω load.
    With speakers wired in parallel:
    Two 8Ω speakers will present a 4Ω load.
    Three 8Ω speakers will present a 2.7Ω load.
    thank you very much for the help! nalilito kasi ako sa "8Ω" what does this mean?
    Jan 2004
    That is the symbol for ohms... You need an amp that can put out 125W on an 8ohm load.
    Free air pala yang ganyang sub, just found it on the JL website. That's a real space saver.
    Mar 2005
    -trojan-
    ano ba yung amp mo?!
  4. #4
    whats your budget? branded amplifier prices are 10K and up.
    Apr 2005
    wala pa akong amp. maghahanap pa. kaya nga i'm asking around muna kung ano ang good match with these before i start looking for an amp.
    thanks!
    Apr 2005
    i have 2pcs of these subs pa, in a sealed box.
    Mar 2005
    total JL naman yan. try finding a 300 watts amp. yung rockford, or audiobank... audiobank mas ok sa budget mo...
  8. #8
    mmm... you would need a lot of juice to power those babies. whats the RMS rating? so that we can narrow down your choices.
    Mar 2005
    -ILD-
    kaya mo yan. magkano kaya ang budget ni trojan?! and kung brabd concious ba sya?!
    Jan 2004
    Ah... so having two, and wiring it in parallel will give you a 4 ohm load seen by the amp... now to work out the power required ... 250W?
    Damn I have to read up on my Physics again.
    Given that the current will simply split into the two loads of equal resistance, and P is simply I^2 R, can you just double P? You also get something like 250W if you double I, square it and multiply by 4 to get P.
    Haaay... wala bang Physics guru dito?
    Mar 2005
    calculate na toh...
    Apr 2005
    wrms ng sub is 125. so since dalawa, 250w ang kailangan ko na amp the minimum? how bout the 8ohm? san papasok yun?
    maraming salamat talaga! ndi naman ako brand concious, kahit anong amp basta kaya ang mga subs.. hehe
    Jan 2004
    Wire the two subs in parallel so you will get 4 ohms as seen by the amp. So you need 250W x 1 into 4 ohms...
    Apr 2005
    woooowwwww.....
    so sirs, i need to wire the subs in parallel para maging 4ohms and since 125watts ang wrms per sub and i have 2 of them, the amp that i should be looking for is a 250watts 4ohm stable the least?
    thanks!
    Jan 2004
    Ask Winterpine if they have the new RF P2502 model already. 716 4831. Should be around 10-13k.
  16. #16
    the_wildthing: Ilang RMS niyan?
    Apr 2005
    is this a 250watts na amp? may mas mura kaya na kaya din ang subs na to?
    Jan 2004
    http://www.rockfordfosgate.com/produ...h%20Amplifiers
    60 x 2 * 4 ohms
    125 x 2 * 2 ohms
    250 x 1 * 4 ohms Bridged
    RF quotes RMS.
    Apr 2005
    chiefs, meron kayang mas mura na amp na kaya din ang mga subs na to?
  20. #20
    Trojan: You can look for 2nd hand old school amps. baka maka chamba ka.
Help in Knowing what amp will match a JL ib4
