Results 1 to 13 of 13
    Mga bossing, patulong lang po sana ako kung saan and kanino pwede magpaayos ng trunk ko na 12" subs, mejo plain kasi ang pagkakagawa sa trunk, ang problema pa po, ang hirap kunin ng spare tire, kailangan alisin pa muna ung sub box. patulong naman po mga sir, TIA.
    well, kung may subs ka, talagang problem yung trunk space na kasi kailangan ng subs ng exact box specs to perform to its potential. but if you take the high cost of those slim type subs na kasya sa ilalim ng seats, thats your best bet.
    wala po talaga choice pagdating sa normal 12" subs... kakain talaga ng space yan sa trunk. in my case i let them put the wiring on the side of the box para madali kalasin kung maflatan na. hehe
    hth
    use a sealed box then buy a donut tire, works for me. ang dali bunutin ng spare tire.
    Bro eto low cost solution.. kung ang sub box mo ang speaker connection hindi clip type (yung red and black) pagawan mo.. the if you have flat tire and want to remove your spare, just unclip the speaker connection bring the sub box out just make sure off ang HU mo baka mag short and wires yari amp mo... then access the spare tire.
    If you have some budget re design your wood works, use a sub woofer that has less volume requirement in a sealed box, design that your amps is placed on both sides of the trunk (assuming 2amp system ka) make a false flooring doon sa area ng spare tire for easy access.
    you can go to any good known shops around all you need to tell them is what you want and the design you need.
    Quote Originally Posted by gonzo View Post
    +1 ganitong-ganito setup ko. though ung isa kong chipipay na amp nakatago sa likod ng sub box. pero pag nakakuha ako ng isa pang ok na amp sa gilid ko narin ilalagay. amp ko for seps nasa gilid ng trunk. then false floor na may bukasan for spare tire. kahit sinong carpintero kaya gawin to. tito ko nga lang gumawa nung akin eh. hehehe.
    yung akin eto mga ginamit ko. sealed box, tapos isang wood that will serve as an amp rack. check mo yung clip ng sidings ng trunk mo baka pwede mo na don screw para hindi ka na magbubutas. tapos false floor. hindi ko alam kung ano ginamit na wood pero basically pinatong lang siya sa floor. sakto ung pagkakacut. tapos nilagyan na lang ng pintuan sa may kuhanan ng spare tire.
    Thanks sir for the replies, sirs i would like to ask kung saan po pwede magpagawa ng parang pinto para easy access sa spare tire ko. gusto ko na rin sana pagandahin ung trunk, san po kaya pede magpagawa? mga magkano po kaya, TIA..
    Quote Originally Posted by jasper28 View Post
    Yong sa akin instead na ma access ko yong spare tire sa loob ng trunk pinatakpan(welded) ko ang sa ibabaw at ginawa ko sa ilalim na siya pwidi ma access naka hanged and bolted..Im sure kahit saan na talyer pwidi nila magawa yan..kahit e-fix mo na ang set-up mo at puno-in muna ang trunk ng amplifier..LOL..
    Jan 2009
    Quote Originally Posted by flakez View Post
    diba kung sealed ang box,, hindi ganon kalakas ang buga ng subs??
    Quote Originally Posted by yumyum View Post
    hmmm. ported box mas gapang, sealed box naman more accurate so more on sq. kelangan ko sa sealed box is matipid sa space. and ok naman na ko sa tunog niya.
    Dec 2003
    ganyan talaga pag gusto ng sounds.. pero pwede ka naman pa customize ng box na pwede mo pa rin mahugot yung spare tire mo eh.
    dalhin mo lang sa audio shops tapos pa customize ka ng box mo.
    Apr 2008
    i've seen one sa friend ko, yung amps nya and other wirings nakascrew sa back of the seat... so pag naflatan sya all he have to do is disconnect the sub conncetion and pull out the box... well shempre kailangang pa din ibaba ang box para mhugot ang tire pero atleast madali tanggalin sa wirings
    Thank you mga sirs sa mga pieces of advise. I brought my problem to Jefftan last saturday, although wala siya dun. They did something my trunk and subs, mejo nahirapan nga sila and mejo kinabahan din ako sa pagkakagawa, hindi ganung maganda yung appearance pero it works na rin, ok na rin para sakin, i'll show you some pix pag nakunan ko na, hehe.
    Jun 2008
    ^pls do sir
help on trunk space with sub!
