Results 1 to 9 of 9
July 3rd, 2005 08:31 PM #1
mga frendz, tanong ko lang ano magandang set up sa bagong crv? ung sound clarity ang importante pero may konting boom boom. wala kasi ako talaga alam pagdating sa sound set up. hindi ko alam mga brands na maganda. mga around 20k ang budget... ano ba the best na mairrecommend nyo?
July 4th, 2005 12:54 PM #3Originally Posted by mijyet
October 9th, 2005 10:40 AM #6
make it at least 30k para di naman msyadong chipipay setup mo, sayang bnew crv pa naman.
October 10th, 2005 11:49 AM #7Originally Posted by mijyet
Hi! I own a CRV 2003. In such case same body naman. =) Let me share what I did. =)
Stock all. I just added two things then so far, for me, nagustuhan ko na yung tunog. Nagbalance out na. Yung stock na speakers natin is shallow basket. So medyo matinis yung tunog. Kulang sa mid. I dont know if same pa din yung speakers na naikabit sa version mo.
I put a 15" Boston Acoustic sub woofer and matched with a Kicker Class D amplifier na 800 watts. Yung amplifier, linagay ko sa ilalim ng lamesa. Dun sa open space na lalagyan sa ilalim then yung box na 15" sub. Pinagawa ko sya sa TEAM sa may banawe malapit sa Quezon Ave. Malinis trabaho. Hindi tin daga sa presyo. Magandang klaseng plywood din ginamit for the box.
The whole setup is at around 35K lang. I know may kamahalan despite na walang separates pa. =) Pero ok naman tunog. Balance. Nagkaroon ng semi mid and low.
Hope this helps.
October 14th, 2005 01:22 AM #8
i own a 2002 crv. Pangit nga talaga midbass and bass nya pag stock. Probably because of the speakers. Kelangan mo parin ng seps at kahit amplified sub at the back ok na. I used the hott setup seps in front powered by a v12 amp. and a ryan audio amplified sub in the rear. Ok na siya if hindi naman sobrang lakas ng bayo habol mo
- Sep 2005
- 29
October 14th, 2005 01:57 AM #9good day po. I own a 1998 crv and planning to customize my bumper and add some body kits. can you guyz help where to find this shops? thanks..
10 years validity ko yehey , kaya lang sa june pa makukuha physical card :twak2: :rolleyes:
