Results 1 to 2 of 2
    Jun 2006
    Here is a tutorial from JL Audio on how to properly set your amps gain controls. This is the best you can do short of having access to an oscilioscope (tama ba spelling?)
    http://mobile.jlaudio.com/support_pages.php?page_id=143
    You can download test tones here: http://www.realmofexcursion.com/
    You can compute your target voltage here: http://www.subwoofertools.com/forum/setgain.asp
    Only drawback with this method is you are setting your amp for the rated capacity. If your amp is underrated, you will miss out on some watts. But afaik, the only way properly set rest of the watts is with the use of an o-scope. If you have one you probably don't need this guide anyway.
    Here is another guide from Elemental Designs, may video and text version: http://www.edesignaudio.com/edv2/gains_video.php
    Jun 2006
    I stand corrected. Thanks to the power of the Internet, here is a tutorial from Rockford on how to measure your amps wattage
    http://www.rockfordfosgate.com/scrip...hp?p_faqid=468
How to set gains correctly
